Question about Hozelock Cyprio Prima Xl 3400 Gph Pump
Bought a Hozelock Cyprio last year and just got round to getting it my pond a couple days ago. It worked to start with but when I switched it on just now, nothing worked. I've changed the fuses (and the whole plug) but no joy. Any advice???
5 Suggested Answers
Jeff the TV
  • 82 Answers
SOURCE: How to set up a Hozelock cascade 1500 pond pump
if there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Posted on Jul 26, 2009
SOURCE: My Hozelock Cascade 3000 has recently operated
I have bought a replacement pump
Posted on Sep 09, 2009
  • 56 Answers
SOURCE: I have a brand new hozelock easyclear 6000 pond
Sorry to hear of your setback but hopefully we can get you back to worrying about your pond occupants rather than the equipment. First remove the filter cover and filter and give the impeller a gentle turn to feel if the bearing or motor is jammed. If it turns freely try powering the unit to check if the impeller turns, sometimes the impeller needs a little bump to get it moving at first. If nothing still happens return the pump for a replacement.
Posted on Mar 29, 2011
SOURCE: Hozelock 1313-0000 pond filter, clips won't clamp
I have exactly the same unit as you and also suffered the seized clip problem. I found this was due to debris (fine grit) getting lodged under the clip hinges ands the easiest way to get rid was to flush it out with a high pressure water jet. also you need to make sure that the large "O" ring is seated properly. The clips latch easier when a downward force is placed on the top.
Hope this helps.
Posted on Sep 17, 2011
My pond pump keeps stopping and starting
THIS COULD BE THAT THE THERMAL SAFETY SWITCH IS DOING THIS INDICATING A MOTOR IS OVERHEATING , MOST TIMES THEY START CYCLING THIS WAY MEANS A CLOGGED OR DEBRIS FOULED PUMP IMPELLER OR DRIVE SHAFT , ALSO CAN BE MOTOR BEARINGS/BUSHINGS HAVE RUSTED UP , THIS IS A VERY COMMON THING TO HAPPEN IN A MOTOR THAT STAYS OUTSIDE
Jul 28, 2012 | Hozelock Garden
Need instructions on how to install hozelock cyprio filter & pump
need instructions on how to set up filter, hazelock cyprio please
May 21, 2011 | Hozelock Cyprio Prima Xl 3400 Gph Pump
The motor in my hozelock ac2 keeps opening and closing and the display is blank. I've put in new batteries but the problem persists. Any advice on how to fix this?
Same problem for my Hozelock ac2 after two years working couple times everyday. No warranty, no Service Center nearby. Two options: discard it or repair it myself. Using a small screwdriver I removed the front cover and then the sealed transparent lid covering the keyboard. Humidity was damaged all contacts so I cleaned using compressed air, put new batteries and set up all again. My Hozelock ac2 is working again. I think the product life cycle is two years and as usual also has "planned obsolescence". -Arthur RS
Apr 20, 2011 | Garden
I bought a Hozelock Ultra 9 (model 2684) last year for watering the garden and cleaning the car.It now leaks very badly from around the trigger. Can I take it to bits and mend it? Are there any...
HI - Simon fom Hozelock. I am afraid they are not repairable in this area. The most common cause of this failure is due to ice forming inside the gun and forcing the internal plunger and O rings out - causing a leak. All sprayguns should be protected from freezing. If this isn't the cause (only you know !) And it is 1 year old, we would replace it under warrenty contact us for help www.hozelock.com for details. Simon
Mar 09, 2011 | Hozelock Garden
Hi, I have a Hozelock Cyprio 1313 filter I inherited with my pond and new house. I Cant seem to get it working without water pouring out the two holes on the top and elsewhere. I'm not sure if I am putting...
Hi - I'm Simon from Hozelock. There should be a big o ring that goes between the lid and the tank to make a seal - is that missing ? Also there should be clips that hold the lid to the tank. Both pieces are available as spares, at www.hozelockservice.com - any probs contact info@hozelock.com or @hozelock (twitter) or Hozelock on Facebook. Best wishes.
Feb 25, 2011 | Sport & Outdoor - Others
Hope this helps.
Jun 05, 2010 | Garden
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
How do i take apart and fix my Hozelock Titan 1450 pump''
http://www.hozelock.com/uploads/pdf/spares%20manuals/2008%20AQUATICS.pdf
Apr 04, 2009 | Garden
Hozelock Cyprio Prima Xl 3400 Gph Pump Logo
42 people viewed this question
Top Hozelock Garden Experts
richie46
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
