Question about Bulova Watch
How to adjust the time on the levis watch - Bulova Watch
SETTING DATE&TIME
i cant get a manual for this but watches have standard mechanical function so maybe this will do.
the center crown of the watch right side of the picture, loosen the crown. Be careful, some crown have a screw function so if your bulova has this don't force to pull it to prevent damage. if you have loosen the crown, check if can be turn it, if yes pull gently the crown, first pull date adjust,second pull time adjust.
This is the proper way to adjust you day and time.
say you want to adjust your watch to (date)10th (time)10:15am
adjust your date to 9th, then move your watch hands clockwise until the date change at 12oclock this is the evening time (PM) continue moving your watch hands until you reach 10:15am.
if your crown is a screw time remember to turn it close tightly for waterproofing.
Dec 13, 2010 | Accutron BULOVA men's 26B62
I don't know how to set the time on my trailsman sport watch the number on the back of the watch is lwl189b 107 cr2016
Thank you for contacting FIxYa.
I dont know anything about this watch, Is it a digital? If so, here are generic instructions for digital watches that might help.
CHANGING DIGITAL TIME:
  • Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.
  • 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.
  • 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.
  • 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.
  • 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.
  • 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.
  • Best regards. Jewel
    Sep 14, 2010 | Watches
    How to set time on my Casio Lw-200 Kids watch Its a digital watch
    Thank you for contacting FixYA.<br /> <div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none"> <li id="jsArticleStep1" itxtvisited="1"> Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.<br /></li></div> <li id="jsArticleStep2" itxtvisited="1"> 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.<br /></li> <li id="jsArticleStep3" itxtvisited="1"> 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.<br /></li> <li id="jsArticleStep4" itxtvisited="1"> 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.<br /></li> <li id="jsArticleStep5" itxtvisited="1"> 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.<br /></li> <li id="jsArticleStep6" itxtvisited="1"> 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.<br /></li> <br /> For more Casio info go to:<br /> http://www.casio.com/support/<br />Best regards.
    Aug 24, 2010 | Casio LW200-1AV Wrist Watch
    Watch is loosing time
    mcdevito75 here, Best Bet for your Longines watch, visit a small watch repair shop in your area for this timeing adjustment.
    Jun 27, 2010 | Longines 2 Tone, Automatic, 1970s Watch
    Adjust the time in a casio g-shock shock resist watch
    You can get instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals", watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Click on "search" and the download your instructions.
    Mar 08, 2010 | Watches
    Kennet Cole Mens Watch Model A126-08 KC1494 How to adjust time
    I have a Kennet Cole Mens Watch Model A126-05 KC1296 and I'd liked to know
    How to adjust time
    Jan 16, 2010 | Kenneth Cole Watches
    Adjust time on casio telememo 30 watch
    how to adjust time on casio telememo watch
    Oct 26, 2008 | Watches
    Need too set time on my g shock casio watch
    Press Adjust and hold until blinking city appears.
    Press Mode until DST appears flashing.
    Press Recieve until mode that you want appears ON OFF AUTO
    Press Adjust until not blinking city code.
    Mar 10, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    IAN DANIELS WATCH TIME ADJUSTMENT
    set time on casio sport watch
    Feb 06, 2008 | Watches
    How to adjust the date in tagheuer watch
    Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
    Dec 05, 2007 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Bulova Watch Logo
    824 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Jimmy Accardi
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
