Question about Toshiba Satellite P105-S6024 Notebook
Help with taking laptop apart
I have removed all of the screws from the bottom of the computer. I try to pull it apart but something in the center of the computer is holding it together. It is being held from up under the keypad. I was wondering if you could help me with this problem please.
    Problem Solver:
  • 5 Answers
I have a toshiba satellite p105-s6024, and have had to take it apart multiple times. I have also taken apart the a105 series, and they both presented me with this problem. i finally found the solution when i took off the top panel that houses the power button (P105), or the panel with the speakers (A105). It can be snapped off with a small flat screwdriver at about 4-5 snap points along the border of the F-keys and the black trim of the top panel. under there you will find 3 screws for the keyboard, and four screws for the monitor hinges (2 per hinge). I hope this helps! if you need pics, i'll be taking it apart again soon, just e-mail me at cytokinesis55@Yahoo.com
Posted on Jul 20, 2008
Bio passwod removal hp laptop
How to Reset an HP Laptop BIOS Password
Reset the password on any HP laptop.
Reset the BIOS password on an HP laptop computer when it has been forgotten or when preparing the laptop for sale to a new owner. Learn how to erase an unknown BIOS password by physically disconnecting the internal batteries. Avoid spending hundreds of dollars at a service center to make changes that can often be performed at home by anyone with the ability to take an HP laptop apart and put it back together again.
Items you will need
  • Small screwdriver set
  • Flashlight
Step 1
Power down the computer if necessary by holding the power button down for six seconds until the power shuts off.
Step 2
Disconnect the power cord from the HP laptop computer. Remove the battery by flipping the computer over onto its cover and releasing the battery clips as indicated by the illustrations on the bottom of the laptop or in the owner's manual. Lift the edge of the battery nearest the clips up first, then pull the battery out of the laptop.
Step 3
Remove the screws that hold the hard drive cover in place and remove the cover. Take the hard drive out of the laptop by removing the two retaining screws and pulling the drive gently away from the connector, then lifting the hard drive bracket or tray out of the computer.
Step 4
Remove the screws that hold the memory compartment cover in place, then remove the cover. Remove the memory modules from the sockets by spreading the metal retaining clips gently apart and allowing the module to spring upward. Pull the memory straight out of the socket at the angle it rests at when sprung from the retaining clips.
Step 5
Remove the Real Time Clock (RTC) coin cell battery from the memory compartment by pressing the retaining clip and pulling the coin cell battery out of the socket.
Step 6
Allow the computer to sit without the battery for an hour, then reinstall the memory and hard drive, but leave the coin cell battery and the main battery out of the system. Connect the AC power adapter to the system and power it on to clear the BIOS password.
Step 7
Power the system back down and remove the power cord to reinstall the coin cell battery and main battery.
hope this helps
John
Nov 17, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Hi I cracked the screen on my toshiba Satellitle L670-10N and have ordered and received a replacement. However, when trying to remove the broken screen, I cannot unscrew the screw on the bottom of the...
The screen portion of the laptop should be removed from the keyboard portion. There should be screws in the back of the laptop, or under a removable plastic piece directly about the keyboard. This will have to come apart anyway, because you have to remove the video cable from the mother board to replae the screen anyway.
Mar 21, 2011 | Toshiba Satellite L670D-ST2N03 Laptop...
Proper way to remove front passenger door panel
some screws.some clips start with screws. one in pull handle also.
Feb 19, 2010 | Mercury Grand Marquis Cars & Trucks
Removing the front panel -bulb replacement
There is no other screws other then at corners at back of TV that you have already removed/ loosen.
Please pull lower front from its top corners as its lower part has hooks with bottom of TV front.
Below image will help you to remove front panel for lamp replacement in this TV..
Thanks.
Sep 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
How to take apart hp ze5570us to see what is wrong with the plug socket for the charger? I have taken all screws out but the computer does not seem to be coming apart easily.
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Jun 15, 2009 | HP Pavilion ze5570us Notebook
I have a toshiba A135-S4656. The fan needs replaced or a cleaning
Getting to the fan on your laptop is VERY DIFFICULT. There's a lot more screws, wires and snaps holding the computer together than you'd imagine. It's best to get a professional to do it, however less and less people these days are willing to pry open someone's laptop because a lot can go wrong.
If you've backed up your laptop and are willing to risk not being able to put it back together, then go ahead. To get to the fan you actually need to get through the top. Unscrew every screw you can find on the back and the bottom. You'll need to open up the hard drive and motherboard because there's screws there too. Pry off the piece covering your speakers, then the keyboard, then unplug the ribbon wires by moving the little plastic things, all the while unscrewing everything you see. Good luck.
Mar 21, 2009 | Toshiba Satellite A135 Notebook
I need to get into the case of a Samson V25 laptop.
The case comes apart at the seam that runs all the way around it. The bottom part has little projections in it that little tabs in the top part fit into. You can use a small screwdriver to pry the case apart (acutally something plastic will ensure you don't leave marks).
But--be careful. You actually have to press in a little on the top half (or possibly the bottom half--depending on the computer) as you are prying apart so you don't break the tabs. Take your time!
Also, you probably will have to remove the posts holding the video and printer plugs.
Jan 23, 2009 | Computers & Internet
The connection where you plug in the power on my compact presario R3000 laptop is broken. The female part that you plug into is loose and probably broken away from the solder on the mother board it self. I...
Before you pull apart your laptop, check the male connector and power cord of the adapter, check it with a multimeter and or plug it into another Compaq. You could have a broken wire in the power cord, it could save you a lot of work.
To pull apart the laptop, remove the battery, hard drive and CD drive first.
Then remove all the screws from the bottom of the laptop, plus the screws on the back that holds the LCD's hinge to the laptop base.
Take a note of where the screws come from, some may be shorter that others.
The remove the keyboard (the screws should already been removed from the bottom of the laptop).
Carefully remove the plastic cover next to the base of the LCD screen, This may also cover the hinges, if necessary fold the screen flat to enable you to carefully pry this cover up and off.
The plastic top cover is clip fastened to the bottom of the case, carefully prize apart from one side and gradually work around the other sides.
You can now remove the LCD, there are two connects attached to the motherboard, unclip these.
The motherboard is under the keyboard and plastic top cover, there are screws securing it to the plastic base, remove these and you should be able to free it from the base.
Now you can solder/fix the power connector.
I suggest you use a temperature controlled soldering iron.
Don't use too much force, you might crack the plastic parts.
Best of luck and have fun.
Jan 12, 2009 | Computers & Internet
Flash bios crash
The only 2 way to fix it is to replace the motherboard or:
Take the computer apart by removing all visible screws. And slowly and carefully removing all parts. Start with screws under keyboard on bottom of chassis. After you remove the keyboard you will see more of a hint to get the laptop apart. Go to tomshardware.com and search the site for how-to on disassembling a laptop. After you get it open you should look for your bios chip , the picture is attached here. If it is socketed you can get the numbers
and do an
 internet search or call acer and get one from the manufacturer.
Here is one for a toshiba laptop: http://www.irisvista.com/tech/laptops/Toshiba_Tecra_S2/pull_apart_laptop_1.htm</url>
Jan 07, 2008 | Acer Aspire 5100 Notebook
Twinhead 12D Laptop
Are you sure you have all the screws out, there is a small plastic disc on the bottom of the laptop underneath the card slot, this needs to be removed to access a screw (obviously take out plastic blank in slot first).
And there is not much reason to dismantle LCD either.
What is it you are trying to do.
Dec 04, 2007 | Twinhead SlimNote N12PI Notebook PC
Toshiba Satellite P105-S6024 Notebook Logo
249 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
