Question about Microsoft PowerPoint 2003 Student & Teacher Edition (yl800055) for PC
Identify and label the parts of powerpoint screen window.
Tip
How to recover corrupted PowerPoint file using TEMP folder?
Today tip will help you to recover the unreadable and corrupted file of Microsoft PowerPoint. Normally PowerPoint open files can become corrupted when you are trying to save it or if you were working on it and your PowerPoint application or windows crashed due to power failure. Windows saves a duplicate copy of working file as a temporary version. There is no need to use any third party software to manage these types of corrupted files, because you can recover them from TEMP folder.
Follow the given steps to recover the corrupted files in MS PowerPoint:
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
First click on Start button then click on Search option to start your search process.
Here type the *.TMP in "All or part of the file name" box then choose the "Local Hard Drives" option in "Look in" box.
Now click on Search button to start the search process of temporary files on your system local drives.
After some time, windows locate the list to temporary files. Here arrange the all temp files as Date modified.
Now open the PowerPoint and try to open these temp files or double click on that file to run in PowerPoint
on Dec 03, 2009 | Computers & Internet
How to make powerpoint?
How you present the material in a speech can say as much to your audience about your expertise on a subject as the actual content of the speech itself. Microsoft PowerPoint is a powerful multimedia presentation tool capable of producing captivating and informative slideshow presentations. Microsoft PowerPoint is a program that is part of the Microsoft Office suite and has been emulated in open-source programs such as OpenOffice.
Open Microsoft PowerPoint. In Windows computers, PowerPoint can be accessed by clicking "Start," then "All Programs," then the "Microsoft Office" folder. Mac computers will install a link to PowerPoint on the taskbar. Click "Design" and choose one of the templates that open in the design tab. Additional designs can be downloaded from Microsoft.com. Click the area of the slide that says "Click to add title" and type your desired title. This slide is referred to as the title slide. Create a new slide by right-clicking on the title slide and choose the "New Slide" option. Windows users can use the keyboard shortcut by holding "Ctrl+M" with PowerPoint opened. Click the area of the slide that says "Click to Add Title" to add a title or "Click to Add Text" to add text to the slide. Type the information that you would like to display on your presentation in the text box. The text box gives you the option to add text, pictures and tables and even create graphs by clicking on one of the respective icons at the center of the text box. Click on a slide that you would like to add a special transition to and click the "Transitions" tab. Select a transition by clicking on it. Click on a text box that you would like to animate and click the "Animations" tab. Select an animation by clicking on it. Click "File" and "Save" to save the PowerPoint presentation. Open the saved presentation, pressing the "F5" button to open the presentation in full-screen mode.
Jan 15, 2013 | Samsung Computers & Internet
Unable to locate powerpoint on my pc
Powerpoint is a part of Microsoft Office, not a part of Windows XP. Maybe you will have to buy Office to get Powerpoint.
Oct 31, 2009 | Microsoft Windows XP Home Edition
Sparks off part labeled gs 22
If you can post a pic of the component I can identify it for you and list where to get the part at.
Oct 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
When receiving attachment that requires -power point slide show- Outlook express -cannot run it-- message pop up says "the file does not have a program associated with it for performing this action.Create...
  • Open up Windows Explorer. (The Windows Key + E, on many keyboards.)
  • Find any file with the PPS extension. For example somefile.pps.
  • Right-click on the filename, and select Open With ....
  • Even if the PowerPoint or PowerPoint Viewer is already listed don't click on it. Instead, select Choose Program at the bottom of the list that's displayed.
  • In the resulting dialog box you should find PowerPoint, or PowerPoint Viewer, and click on that.
  • Click the box labeled "Always use the selected program to open this kind of file".
  • Press OK
Jul 10, 2009 | Computers & Internet
Saving files before uninstall
Just put the PowerPoint CD into the drive. An autorun program should automatically start the PowerPoint installation program. From there, just follow the instructions on the screen. You should not need to change any of the default setup options.
Apr 10, 2009 | Microsoft Windows XP Home Edition for PC
Microsoft powerpoint
Microsoft PowerPoint is a presentation program developed by Microsoft. It is part of the Microsoft Office system, and runs on Microsoft Windows and the Mac OS computer operating systems. The Windows version can run on the Linux operating system, under the Wine compatibility layer.
PowerPoint is widely used by business people, educators, students, and trainers and is among the most prevalent forms of persuasive technology. Beginning with Microsoft Office 2003, Microsoft revised the branding to emphasize PowerPoint's place within the office suite, calling it Microsoft Office PowerPoint instead of just Microsoft PowerPoint. The current versions are Microsoft Office PowerPoint 2007 for Windows and 2008 for Mac.
You can learn more here:
http://en.wikipedia.org/wiki/PowerPoint
Regards
Jan 22, 2009 | Microsoft PowerPoint for PC
Unable to open .pps attachments from windows mail in windowsvista
If you have Windows XP:
Manual fix
  • Click Start, Run and type CONTROL FOLDERS
  • In the Folder Options applet that opens, select the File Types tab
  • Scroll down and locate the following entry:
PPS (Microsoft PowerPoint Slide Show)
  • Click Advanced
  • Click the New button
  • Type Open in the the Action: text box
  • In the Application used to perform action: field, type the following exactly:
For PowerPoint Viewer 2003:
"C:\Program Files\Microsoft Office\PowerPoint Viewer\pptview.exe" "%1"
For PowerPoint Viewer 2007:
"C:\Program Files\Microsoft Office\Office12\pptview.exe" "%1"
  • Uncheck the Use DDE box
  • Click OK, OK
  • Close the Folder Options dialog
-Tha Mp3 Doctor
Dec 31, 2008 | Microsoft Windows Vista Home Premium with...
What are the uses of microsoft powerpoint?
Microsoft PowerPoint is a presentation program developed by Microsoft. It is part of the Microsoft Office system, and runs on Microsoft Windows and the Mac OS computer operating systems. The Windows version can run in Linux operating system, under the Wine compatibility layer.
PowerPoint is widely used by business people, educators, students, and trainers and is among the most prevalent forms of persuasive technology.Beginning with Microsoft Office 2003, Microsoft revised the branding toemphasize PowerPoint's place within the office suite, calling itMicrosoft Office PowerPoint instead of just Microsoft PowerPoint. Thecurrent versions are Microsoft Office PowerPoint 2007 for Windows and2008 for Mac.
Nov 25, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft PowerPoint 2003 Student & Teacher Edition (yl800055) for PC Logo
2,127 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
