Question about Toshiba Satellite A60 Notebook
When i power up my toshiba laptop, i get please wait and then nothing happens
  • Toshiba Master
  • 17,129 Answers
There are erros in the lapttop and I aould advise that you can use a good scan to test for virus in the OS.
Also please clean the temp files, history, cookies and unwanted programs installed to make the system faster.
Use a good registery cleaner-- check on advanced system care.-- to download a freeware which is quite useful.
If these test do not improve then there can be program files deleted.
Use the power on button to press for few seconds and the laptop will shut off forced.
Posted on Sep 02, 2010
  • 57 Answers
You could try and boot from a recovery disk as it sounds like a bad problem
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Laptop will not come on
Although other possibilities can be at fault, if it does so little after power on, the CPU itself may have failed. The very first actions a PC does when turned on is to read the information stored in the CMOS to determine what hardware is on board. After doing this, it turns to the hard drive for a check to see if it is readable and then the CPU (your microprocessor) Intel or AMD takes command. If the hard drive is at fault, a message will inform you that the hard drive either cannot be found or is unreadable. If the hard drive light flashes once, then the BIOS  has made contact and then the hand-off to the CPU begins. If it is stopping dead at that point, the CPU is the prime suspect.
What fairly often happens is first a failure of the CPU fan that sits directly on the heatsink that transfers the heat from the CPU and then the heatsink is bathed in air from the fan. If the fan has failed (all too common) or is impeded by a dust accumulation, the CPU overheats and if the maker has not made any provisions to shut down the CPU, it dies.
There is a possibility that this kind of problem can be caused by a failure of the RAM (memory) but establishing what has failed is only possible through substitution of one or both of those devices.
If you are somewhat skilled, opening a laptop requires small Phillips screwdrivers to remove case screws from the side(s) and bottom, then the case still (in most cases) needs to be carefully pried open. The mating halves normally snap together as well as being fastened with said screws.
Most likely the keyboard will also have to be freed from a couple of screws and, depending on the length of the flat cable connecting it to the system board, can be pulled forward before or after the cable is pulled.
The CPU will be easy to spot; it's one of the large clumps on the board. Check its fan to see if the blade turns freely and is not impeded by dust (these things have hardly any torque), then with two fingers, positioned on either side of the blade, check to see if it rocks side to side. This would be an indication that the bearings have failed and it will need to be replaced.    The CPU is held by clips but make sure you have no static charge before removing any internal part. Just 'equalize' the charge by touching an exposed metal cover or other chassis part. Memory is normally accessible from the bottom of the case.
Now comes the bad news; there are still myriad other components that can keep a PC from booting when no error message is present since there are numerous support functions which can interfere with the startup of system. I've given you the most likely points of failure; CPU or memory.
Posted on Jan 01, 2009
Davethesnake
  • 689 Answers
SOURCE: My Toshiba laptop is stuck
1]--try waiting for an unreasonably long period (10)min's without touching the keyboard.
2]--re-install operating system with correct recommended system
3}--check manual/manufacturers site to see if you can restore factory settings another(hotkey) way
Posted on Mar 14, 2011
Laptop gets stuck welcome screen when
It sounds to me like a file is corrupt and there is a number of reasons for that. If you press F8 just before it tries to boot, you will have access to a menu. Try running safe mode to see where the issue is.
To run Toshiba Recovery:
Choose the Repair Menu in the Windows boot menu (Press and hold F8 at the Toshiba SplashScreen.
Or
Hold the Zero key during Power Up.
If that doesn't work, you may need to order a Recovery Disc from Toshiba.
Mar 07, 2014 | Toshiba Computers & Internet
Toshiba Satellitte A105 lap top is in hibernating and I can't wake it up. I have alread removed the batter, press the power key for 10 seconds and then put the battery back on. Nothing happens...I...
it happens sometimes you can either try to:
  • Press a key and wait for a response
  • Look and see if your laptop has like a hibernation or standby key on the keyboard
  • Have a look and see if you have a fn key and look to see if there is a power management button
  • remove the batterys and the mains hold down the power button for 30 seconds and wait a couple of minutes and connect everything back up again
However it could be something to do with your BIOS, go into your BIOS and see if there is a power management option in BIOS andplay about in power management sometimes there is a option to enable APM advanced power management if that is enabled disable it.
Jul 13, 2011 | Toshiba Satellite A105 Notebook
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Battery
Try resetting the BIOS in case something happened to it.
Power down your computer. Remove the power cord, the rechargeable battery and the BIOS battery. Wait 10 minutes. Reinstall the BIOS battery, the rechargeable battery and the powewr cord. Restart your computer and enter the BIOS setup.
If nothing happens, your video card may have failed.
Mar 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
Power light on, but not responding
just wait till the battery power gets full.
Sep 24, 2009 | Computers & Internet
On my Toshiba Satellite laptop. When I start it
Please hard push the power button and wait for its shutdown,
after shutdown Please restart the PC it will work, and don't close the screen after your work just shut down and wait for it completely off.
Sep 16, 2009 | Toshiba Satellite A135-S2276 Notebook
Starting controller please wait and then nothing
the printer controller isnt working correctly. it may be a bad controller, hdd or maybe a firmware issue. power down. disconnect controller . let it sit unattatched for 5 minutes .reattatch controller and power back up. may fix
Jun 19, 2009 | Toshiba E-STUDIO 650 Copier
ToshibaSatellite M115-S3094 won't turn on
Pull the ac power and battery out. Wait about 15 minutes and replace both. Try to power back up.
Nov 18, 2008 | Toshiba Computers & Internet
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
