Question about GE Advantium 120 Convection/Microwave Oven
Takes much longer now to heat things
Model SCA1001KSSO2. 1 yr old. Does not heat foods as it did. Takes 3X's longer. Inside on right side is a 4"X6" white broken cover. Is that the problem? Seems GE's micros only last 1-2 yrs.
  • GE Master
  • 9,098 Answers
I think you have two separate problems.
Taking a long time to heat is almost always a failing magnetron.
The cover on the side is the waveguide cover. If your waveguide cover is burned or broken, it will need to be replaced.
It protects the waveguide and magnetron from grewase and food particles, which can cause arcing and damage.
Hopefully your oven is just under the one-year mark and GE will fix it free under warranty.
Otherwise, they will replace the magnetron at no part cost, but labor will be your responsibility.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 10, 2008
Manual
my Daewoo microwave over heats on the right hand side of the external casein wen in use model number is kor6n9rr is there any thing majorly wrong please get bk to me on my email which is bridgetyork @.co.uk
Jul 04, 2013 | Daewoo KOR6N9RR Microwave Oven
Kenmore elite countertop microwave/convection oven
Time for a new cover plate or a new microwave. Depending on the age of the unit, the part may not be available anymore.
Jul 06, 2017 | Kenmore Microwave Ovens
Microwave time has to be doubled to heat or cook food
I don't know how old your oven is, but this might just be due to aging. The magnetron tube which makes the microwaves loses power over time, so it takes longer to heat your food. It also causes the tube to work harder and get hotter, so sooner or later the tube either burns out or causes the safety thermostat attached to it to trip. This causes a dead oven.
The tube can be replaced, but unless this is a high-end model or a built-in, it may be more economical to buy a new oven. New tubes are $75 to $100, and there's the labor cost for the repair. I don't recommend trying to fix microwaves yourself because of dangerous voltages and the possibility of microwave leakage if the repairs aren't done correctly.
Hope this helps. Thanks for using Fixya!
Feb 28, 2010 | Microwave Ovens
Microwave taking much longer to heat food
The microwaves are produced by what is known as a KLYSTRON TUBE. Like anything, early failure is possible. There is also the possibility that the transformer or electronic circuit providing the correct voltage to the KLYSTRON has failed, either from over-use, manufacturing defect, or leakage from the KLYSTRON enclosure, which creates heat.
With microwaves being as CHEAP as they are, replacement should not be an issue.
Feb 03, 2010 | Microwave Ovens
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 1 yr...
If it's less than one year old, it would be fully covered under warranty and you should contact the manufacturer to get it fixed free.
Some have longer warranties, and that will be covered in your owner's manual.
Jan 31, 2010 | Maytag MMC5000 Microwave Oven
Kenmore microwave Model 72 8975590 (750 W) is taking longer to heat food. Takes 3.5 min to bring one cup water to boil, previously took 2,5 to 3 min. Does the element lose power over time?
I can adjust the power level so that circuitry seems to be ok. The longer water boil time could be partially due to the colder winter temperature of the inlet water. We'll just cook the food a bit longer as long as the magnetron is still working.
Jan 21, 2010 | Kenmore Microwave Ovens
My GE spacemaker oven will no longer heat the food. can I replace the heating thing?
Yes, GE Customer Service is here, and they can tell you what model would be a "drop-in" replacement for your model.
If you or someone you know would rather fix yours, which can often be done pretty easily, (on some models the magnetrons have 10 year warranties) please post a NEW FixYa inquiry that includes your full model number from the tag in or on the unit, and the answer to these questions:
- When you try to microwave, do the inside light, internal cooling fan, and the turntable all come on?
- Is it louder or quieter than usual?
- Is it making any odd noises?
(We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.)
Otherwise, if this takes care of you...
Oct 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Feb 01, 2009 | Microwave Ovens
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
GE Advantium 120 Convection/Microwave Oven Logo
348 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
