Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Connect LCD TV to Mac G4 to use as monitor
I have a Mac G4, which has a VGA monitor port as well as a DVI. I bought an Insignia 15" LCD HDTV that has a PC RGB monitor port and came with a cable. The cable will connect the Mac VGA port and the PC port on the TV but all I get is a VGA No Support signal on the TV. Are they incompatible? Am I missing some kind of software that I need? The G4 worked fine when connected to my old fashioned monitor.
  • Anonymous Jan 02, 2009
    llllll
5 Suggested Answers
SOURCE: Insignia LCD TV won't recognize computer input...
i lowered my resolution and now it works perfect
Posted on Aug 11, 2008
  • 458 Answers
SOURCE: RGB port
A VGA & RGB port is the same thing. RGB is Red/ Green/ Blue for seperate input & VGA the video graphics array which does the same thing.
A DVi is an entirely different type of input port for digital input where your VGA port is more for analogue type inputs
Posted on Jul 13, 2009
SOURCE: trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Posted on Feb 22, 2010
SOURCE: Insignia 22'' LED HDTV screen resolution problem with VGA
I think this stems from the fact there is no VGA mode designation (not plug and play) however there are VGA H&V settings that may be overidden from autodect mode under ADVANCED in teh menu. What sux is that it isnt stored and must e reset when input changes. FIRMWARE UPDATE PLEASE INSIGNIA!
Posted on May 22, 2010
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Tip
Connect you HDTV to your Mac.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
Trouble connecting Insignia HDTV 19" to my macbook pro
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
I am trying to use my 32 inch Insignia HDTV as the display for my 13 inch macbook. I got an adapter for the vga, connected everything and turned then on. The display only shows one of my desktop pictures...
--==<[ DVI to VGA vs. DVI to HDMI ]>==-- Caleb, what you really want to do to get your Macbook working with the Insignia HDTV is to >RETURN< and exchange the DVI to VGA adapter for a DVI to HDMI adapter. This is assuming your hdtv has HDMI inputs (which I'm pretty sure all the insignia ones do! I own a 1080p 32" Insignia HDTV and it has 4 HDMI's). The reason you should exchange them is that DVI and HDMI are essentially the same connector (and a better connection than VGA), the only difference between DVI and HDMI is that HDMI additionaly contains two audio channel wires. HDMI (which is a smaller version of DVI) is a digital signal and will give you perfect picture quality compared to the analog 'pc vga' type connector you were converting it to with the adapter you described (not to mention it will probably just work immediately since there is intelligent 'handshaking' that goes on with an HDMI connection, so it will tell your HDTV what resolution to use rather than it having to guess....)
I am guessing by now you solved the problem since it was in June that you posted and it's now November as I write this, but I figured you're probably not the only one who tried hooking it up that way. And most people don't seem to realize that DVI and HDMI are essentially the same type of connection, just smaller, with audio added. So someone will most likely benefit from this posting =)
Best regards, -=VRMan3D=- http://www.vrman3d.com <- 3D Screensavers and in browser 3D Mac/PC gaming for free!
Jul 17, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
DVI connection to DVI port on PowerMac G4
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Rifaa
Aug 02, 2008 | Acer X193W LCD Monitor
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Flat Panel Insignia 19
Lets see the cableing..
So you have a mac with a mini-dvi slot, you have a mini-dvi to dvi adapter, and then Dvi to vga adapter which connects to the tv?
The mini-dvi to dvi adapter doesn't have the analog VGA signal your tv needs. If I understood right.
Apple's mini-DVI to DVI-D cable does not carry the analog signal coming from the mini-DVI port on the Apple computer. This means that instead of buying a single mini-DVI cable from Apple and using a cheap DVI-to-VGA adaptor when you need VGA output, you must purchase another mini-DVI cable from Apple.
May 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
891 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
