Question about Hotpoint WD62 Front Load Washer / Dryer
Machine will not completely drain. Always leaves about 2" of water.
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 03, 2010
My Frigidare dishwasher is not draining so I cleaned the filter. Will there always be a little water left in the lowest part where it drains?
There will always be a small amount of water in the bottom because the pump is an impellor type, not syphon or peristaltic. The water will be whatever is in the drain pipework after the drain cycle has finished. If the machine is leaving a lot of water, the it would be worth checking the drain hose isnt blocked or kinked, and the drain pump impellor moves freely
Jan 11, 2018 | Dishwashers
I have a top laoder whirlpool8564990 it don´t spin well it leaves my clothes soaked and it goes to spinning cycle yet it don´t spin
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Washing Machines
Modelgltf2940fs2
replace control board good luck APPLIANCES R EN
Mar 01, 2013 | Washing Machines
I have a Magic Chef dishwasher that's between 10 and 15 yrs old. The dishwasher doesn't always completely drain and leaves varying amounts of water behind.
The drain pump may be faulty or the drain pipe exiting the machine is in the wrong position allowing drain water back into the system.
Hope this solves your problem
Aug 05, 2011 | Dishwashers
Hi, Bought a Maytag front loading washer #MAH6500AWW about 5 years ago. 1. The amount of water remaining in the machine (if you turn the drum it sounds like SEVERAL gallons of water swooshing around)...
i would say the drain pump is blocked.......... you could take the drain hose and leave open end at lowest point on the floor into a container and let water drain out..........easier if you can get machine to outside door and let water drain outside i did a zanusi last night...stuck in the pump was 9 small coins 1 hair grip and a womans bra under wire............
follow the waste hose at the back of the machine it ends at the pump......... open the pump then check it out...
good luck..
cheers
Apr 04, 2011 | Washing Machines
Machine dot draining, not completing cycle.
check pump filter may be blocked . Pump always got water in it even when empty put towels down and if possible lean machine back wards .and always remove plug from wall before doing any repairs .
Feb 11, 2010 | Washing Machines
Our machine does not always spin the clothes completely "damp"
Hi,  try these:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate my suggestion....
May 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 48102 Front-Loading Washer
I have had the same problem. I unplug the washer for a couple of hours and then run the rinse/spin cycle and it takes care of the problem. I've had my machine for 2 1/2 years and this problem started exactly after the first year ended. The first time it happened, I called for repair but before the repair guys came I tried this and so far it has worked. It happens about every few months.iIt's a pain but so far no repair guy bill, yet.
Oct 06, 2007 | Washing Machines
Hotpoint WD62 Front Load Washer / Dryer Logo
76 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
