Question about Frigidaire FES367 Electric Kitchen Range
Frigidaire stove door looked
During self clean come up with F30 error code. Is there any updates on this product.
  • Anonymous May 21, 2008
    While trying to bake in my over model number FEF366DSB I keep getting the beeping and the oven keepis going back to the F30 error. On occasion I get a F10 error also. What's the fix...Donna Locher
  • tmillette Aug 12, 2008
    i just bought a stove, got it delivered and there is a blinking message under the time display that reads "door Locked" and i am getting an F30 ERRR message when i hit the button to turn on the stove? Any solutions or suggestions?
    Scholar:
  • 150 Answers
Temp was too high or the sensor smoked. this happens, self clean wreaks havoc with the electronics on this stuff. need your model to tell you what the error code means
Posted on May 10, 2008
Frigidaire gas stove, oven will not work. Shows F30 code
That is an error with the temperature sensor.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on. If you still have the problem here is a link to order the replacement part and a video how to replace the part which is fairly easy to do.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/561286-error-f30.html
Dec 10, 2016 | Frigidaire Kitchen Ranges
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
Nov 25, 2012 | Frigidaire FES367 Electric Kitchen Range
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jan 16, 2010 | Kitchen Ranges
Did a self cleaning and it don't work now..door now lock too..
called a guy that sold me the stove to fix it or I would smack him around...he fix it
Dec 28, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Frigidaire FES367 Electric Kitchen Range Logo
343 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
