Question about Philips GoGear HDD6330 MP3 Player
Frozen screen screen is frozen on "loading" I've tried rebooting by holding it to on/off and + volume, but it doesn't seem to work this time - any ideas?
  • 476 Answers
The fault could be down to firmware or a faulty hard disk.
First of all, install and run the Philips Device Manager from the product CD.
Connect the player to the power supply and PC.
If the player is recognised by the PC, select the repair/restore option in Philips Device Manager, and follow the on-screen prompts.
This will format the player and re-load the firmware. NOTE: THIS WILL DELETE ALL TRACKS ON THE PLAYER.
If this doesn't help, or the player is not recognise, then the following might work:
Download the factory software from the following link:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/060421/060421185016_12769.zip&ofn=HDD6330-17-v1.3.zip
Unzip the file to a new folder on your desktop, and open the folder to show the installation files and folders.
Connect the HDD6330 to the power supply and the PC. Before the HDD6330 registers on the PC, press and hold [VOL+] & [POWER ON] to reset the player.
As soon as the player resets, press and hold [VOL-], until PC recognises the player as a removable drive.
Player will show the connection icon on screen but without the bar and battery indicator at the top of the screen. You may need to try this several times to get it right.
When the player shows as "GOGEAR" or "MDJUKEBOX", right click on the drive from My Computer and click format. Click on "Quick Format" and complete the process.
If the player does not allow you to access or format the hard disk, then the disk is probably faulty.
Copy ALL of the files from the new folder exactly as they are (not including "New Folder", into the HDD6330.
When the copy process has completed, safely remove the HDD6330 from the PC, but leave connected to the power.
The player will restart and eventually show "Burn Success"
Press and hold [VOL+] & [POWER ON] to reset the player. The player will restart as normal, and hopefully go into the main menu.
If this still doesn't work, but the process worked ok and the player still froze on "Loading" then the PCB is probably the cause.
You can obtain a replcement from www.cheapestelectrical.co.uk
They are not listed on the site, but they definitely have them available. Unfortunately, they don't have the PCBs for the HDD6330.
Go to the about us page and contact them by phone or e-mail.
Posted on May 14, 2008
Nokia 820 screen is frozen
Is the screen frozen on an app? If yes, have you tried to reboot the phone? If holding down the power button for 12 seconds doesn't bring up an option to 'slide down to power off', try pressing the volume down button and the power button at the same time, and hold them for 12 seconds. If that doesn't reboot the phone, you should be able to remove the back and take the battery out, count to 12, and replace the battery to reboot it.
Jul 27, 2016 | Nokia Cell Phones
DGM t-1006 tablet has frozen. How do i reboot?
Try holding the power button and the volume down button at the same time for at least 8 seconds. That might open the reset screen.
Jan 25, 2015 | Tablets & eReaders
How do you rest a thunderbolt
First, try this:
From the main home screen, tap menu
Tap Settings, then Privacy
Tap Factory data reset
Tap Reset phone
Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
Turn the power off. If your HTC ThunderBolt is frozen, pull the battery out and reinsert it
Hold the Volume Down button
Press and hold the Power button until the device turns on
You are now presented with a menu that allows for Fastboot, Recovery, Clear Storage, and Simlock
Select Clear Storage by pressing the Volume Down button
Press and release the Power button
Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC ThunderBolt. Once the wipe is complete, the phone will reboot to its factory fresh state.
Sep 06, 2012 | HTC Thunderbolt (8 GB) Smartphone
Dropped phone and now doesn't work
Try any of the below combination.
  1. Hold Volume Up + Volume Down + Power.
  2. Hold Volume Up + Home + Power.
  3. Hold Home + Power.
  4. Hold Volume Up + Camera
Dec 12, 2017 | Samsung Cell Phones
My inspire seems to be locked on one screen that has a red triangle with an exclamation running through it. The phone will not shut down. It is frozen.
It is the boot rom menu for the device. Just power it off then back on. IF it comes back then your OS on your phone is toast.It means your phone is in recovery mode. Hold down the volume up and power button at the same time, then select the option to reboot by going up or down with the volume keys and pressing the power button to confirm your selection.
Dec 06, 2011 | HTC Inspire 4G Smartphone
Why Samsung Galaxy S keeps freezing and crashing. Like 5 times a day. Sometimes it is just me wanting to open up a application or just in the middle of texting. What is happening?
You should backup your contacts and perform a reset on the phone.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Yes to confirm
  1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
My htc surround (windows 7 phone) wont turn back on if i hold the power button on it loads up to the white htc screen and stays on i tried taking the battery out to reboot it self but that didn't wrk...
PLease do a hard reset on the phone and here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Aug 04, 2011 | HTC 7 Surround Cell Phone
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do I reset my lg optimus
See the instructions below how to factory reset your LG Optimus
First, try this:
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
  1. Turn the power off. If your LG Optimus T is frozen, pull the battery out and reinsert it
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Optimus T. Once the wipe is complete, the phone will reboot to its factory fresh state.
Amardeep
For More Tips, Visit My Blog @ http://thegeektweet.wordpress.com
May 27, 2011 | LG Cell Phones
IPod click wheel frozen
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Philips GoGear HDD6330 MP3 Player Logo
127 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
