Question about Refrigerators
Our chilled water supply not working, we have water from supply to fridge, nothing from what appears to be 2 solenoids inside rear l/h behind panel onwards. was workig last night, not now
    Scholar:
  • 150 Answers
A few possibilities: the valve you mentioned (one side is h20 the other is the ice maker), the switch or actuator up in the dispenser or a blockage like frozen line somewhere it happens easy to the units that have a coil of 1/4 in. line instead of a tank
Posted on May 10, 2008
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
KSCS25FJSS01 - The water dispenser line from the solenoid is cracked about 18 inches from the solenoid, before it enters the back of the fridge. It seems easy enough to fix as long as i can get some 5/16...
Good day,
The line runs from the solenoid, into the fresh food compartment where a cooling tank is located behind the crispers, where it is precooled so your dispenser doesn't feed you warm water.
It then comes back out and travels to the door.
Nov 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE GSS22JFMC when I press the water button it leaks
That's where the water line runs to get to the dispenser. You may have to remove the cardboard backing to see it. The line runs from the water inlet valve. That's where the supply line from the house connects to the fridge. One line goes up to the ice maker and the other goes over to the fridge side where it goes inside the fridge behind the crisper to a reservoir where the water is chilled before it goes to the dispenser. Look for the water coming out when someone else tries the dispenser. Look for a fitting that has come loose.
Oct 02, 2009 | Refrigerators
Water leaking from back panel, behind chilled bin. Samsung RS2533RS
the drain at the back is blocked. check the back of the fridge for a hose coming out and give it a blow out . once this is done it will fall inside the fridge (whatever was blocking it)so be sure to empty the shelves before engaging in this and turn the fridge off for safety.
May 11, 2009 | Refrigerators
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Amana ice-maker
Very curious. When you say the tube to the ice maker was disconnected I am unsure as to which tube you are refering to. However hopefully a few pointers might help a damsel. Most units have the water supply enter into the cabinet through a two way water solenoid valve (i.e. one for chilled water one for the ice maker). It then normally enters the top of the freezer section for the ice maker. It then drops down inside the freezer section to the icemaker module. Therefore the only control over the water for the icemaker is the solenoid valve which is controlled by the icemaker "module". A trick is to switch the control at the solenoid valve so that you can use the chilled water dispenser to check if the water valve for the icemaker is working. If it is then you probably have a problem with the icemaker module or the temperature in the freezer section (which you would probably have noticed if that was the case). If you have a problem with the module then you normally have to replace the module as they dont like supplying spares for modules.
Anyway hope this is of some help and good luck.
ps model is normally near the salad drawer or top of the fridge section dependent on brand.
Feb 08, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
