Question about HP Computers & Internet
Computer switches on and off - HP Computers & Internet
  • HP Master
  • 27,725 Answers
First test your CPU then tast all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive or
replace them they are probably old and faulty ?
good luck
Posted on Sep 02, 2010
How do I turn on my wireless connection
If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on.
Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks.
This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop.
When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks.
If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off.
Locate the wireless switch on your computer.
It may be located on either side of the laptop or along the back or front.
If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit.
Determine whether the switch is currently in the "On" or "Off" position.
The switch will be clearly labeled.
Push the switch in the direction of the "On" position to ensure that it is turned on.
If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability.
The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys.
Check your user manual for your computer's key combination.
Troubleshoot problems finding wireless networks
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Jun 13, 2013 | Computers & Internet
How to connect 2 computers to a dlink 4 port kvm switch?
The unit comes with all the cables in order to connect up to four computers to one KVM switch. If you're only using two computers, then you'll only need to connect one computer to Computer 1, and the second computer to Computer 2. The KVM will recognize that only two devices are connected, and generally skip the inputs for computers 3 and 4 until they have a device connected.
Feb 26, 2011 | D-Link DKVM-4K (dldkvm4k4port) KVM Switch
How to Assign an IP address in Nortel 1648T switches
Add a computer to your network, and install Microsoft Windows Server on that computer, and enable its "DHCP-server" component. Then, this computer will supply IP-addresses for all the other computers connected to your switch.
The switch is _NOT_ a DHCP-server; therefore, you need to add a DHCP-server.
Dec 10, 2010 | NorStar Nortel PASSPORT 1648T ROUTING...
Computer on switch not working
Replace the switch, or never turn your computer off.
Oct 28, 2009 | ASUS (VENTO3600BLU) ATX Mid-Tower Case
Replaced ignition switch on Saturn, won't recognize new switch.
Have you tried unhooking the negative battery cable for about 30 seconds and letting the computer reset itself.
Jul 08, 2009 | Saturn SL2 Cars & Trucks
Kvm switch not recognized by one of my computers
Have a close look at the NIC assembly in both the computers.Simply link one computer to the other and see that it detects this or not. Alternatively bypass the switch and try to connect to the broadband from each PC. If u are able to access the net without the switch, then most probably the switch is conked out.Change the switch...................sodeep
Apr 11, 2009 | Belkin 2-Port USB Flip KVM Switch with...
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
