Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Freezer cold Refrigerators food area not staying cold
  • Westinghouse Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 02, 2010
E402b freezing food
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Mar 23, 2014 | Fisher and Paykel Active Smart E522B...
Hotpoint CTH18EAXRAD - Top freezer works but the refrigerator will not stay cold. Its turned up to the coldest
ck for ice in back of freezer this will block air flow to the fresh food area . if iced then the heater or terminator or the defrost timer have failed .. mm feed back pls and thnaks for using fix ya .. mm
Nov 17, 2010 | Hotpoint Refrigerators
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge doesnt stay cold
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
The refridgerator is cool, but not cold.....of course the same for the freezer. the freezer is running, just nor getting cold enough. food is thawing and thermostat is reading almost 40 degress in both...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom wont stay cold top frezer it work bottom ref. wont saty cold and the light work and the fan blowing so im looking for why it wont stay cold at the bottom reg.
make sure you don't have the air flow passages in the back of the freezer blocked with food items or frost. if you have alot of food or items in the freezer and its packed tight it won't let the cold air circulate into the bottom unit
Jul 24, 2009 | Refrigerators
Freezer side cold, food side warm not working
3 possible problems.... Machine is possibly not defrosting (if this is it, eventually the freezer will not work as well) The damper between the two sides is possibly not operating, or the fan on the freezer side is possibly not blowing the cold air into the fresh food side.
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Mar 06, 2009 | Amana AFD2535DES French Door Refrigerator
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Dishwashers Logo
129 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
