Question about Microwave Ovens
Not working, check water warning illuminated.
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 02, 2010
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
Takes about 6 min to boil 2 cups of water-generally slow on all heating
This an early indicator that the magnetron "heats the food" is failing, usually they will go without warning and eventually will need to be replaced.
Jan 25, 2011 | Whirlpool MH1170XS Microwave Oven
How do I add water to the pressa bella dry steam iron
Turn the big yellow top, if it's air tight use a plier and gently turn it. That will the trick.
WARNING!!! Becareful not to over fill the water reservoir by doing so the water boils making it leak. It is extremely dangerously as I steam burned my hand. Other than that u won't have a problem.
Jan 18, 2011 | Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Just quick working no warning. no power.
Remove the cover and check the fuse that should be on the floor near where the power cord enters the cabinet.
Thanks for your interest n FixYa.com
Jan 27, 2010 | Panasonic NN-S543BFW Microwave Oven
Maytag microwave Model MMV5100AA turntable no longer turns. Is this an easy fix? The rest of the Microwave works fine. I think I may have flooded the floor of the microwave with water. It worked awhile...
to be realy honest ,,, yes! but be warned there is a very big capacitor inside this microwave and it will be charged up with 1000's of volts,
if you tuch it, your dead! be warned dont tuch it!!!!!!!!!!!!!!
have you ever seen a stun gun working??? they realy hurt you!!!!
well this microwave has the stun gun's very big brother inside of it and it wont stun you,,,it will kill you!
if i were you i would drop it into the repair man to get him to fix it for you,,, or get a new microwave,, there very cheep now,, is it realy worth killing your self for a fuw bucks?
Oct 25, 2009 | Maytag Microwave Ovens
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
The microwave won't boil water or cook the food we put in. its only saying power 100. what do we do?
I may need more information, however, I suggest that it could be either a dead magnatron or the high voltage fuse link to the magnatron. Check "Demo" mode, WARNING: if you try and replace the fuse or magnatron yourself, make sure of 2 things, 1/ unplug from the wall 2/ make sure the HV Capacitor is discharged before touching anything around the magnatron....also, I may need the model and brand for better diagnosis... Phil
Apr 06, 2009 | Kenmore 63252 Microwave Oven
Control pad does not repond
hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
Sharp R-1611 panel display, lights & touch pad not working
This is a problem with the control panel assembly, which we repair nationwide for $39.95. You can find full details on our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 11, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
11 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
