Question about Asko W6021 Front Load Washer
I can't open the door to the washer, asko 10505. I ran a load, and it's all done washing, but now the door is clicked shut, and I can't figure out how to release it and get the laundry out. can you help?
  • Asko Master
  • 17,129 Answers
After teh program the latch had to disable but possible that the lock got jammed or the end link is not connecting.
Look from the bottom and you can access the lock section to release and get the lock function.
Once it opens use good degreasing spray and then oil then lock as there can be rust or dirt that has got it stuck.
The end program safety link must also work.
Posted on Sep 02, 2010
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
Replacing Motor Brushes, what needs to be done to clean commutator for a Asko 10505 Washing Machine sold in Australia - purchased around 1998 - ignore the W6021 system wouldn't let me post.
To clean the commutator, or armature as it is usually called, simply rub it with a piece of emery paper, or sandpaper, turning it by hand to ensure you clean it properly..
You need to remove the motor to do this of course.
Please rate my solution.
Thanks.
Nov 12, 2009 | Asko W6021 Front Load Washer
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Mar 06, 2008 | Asko W6021 Front Load Washer
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Asko W6021 Front Load Washer Logo
366 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
