Question about HP Officejet 5610 All-In-One InkJet Printer
How to hook up the wireless feature??? - HP Officejet 5610 All-In-One InkJet Printer
  • 28 Answers
Press the wrench key on the printers front panel and then look for wireeless option or network option in the menu..Press ok on wireless menu or network option and then look for an option Run Wireless setup wizard by pressing right arrow key...then press ok on that and type in the neywork name of your wireless router known as SSID and after that press ok...then type in the security key of your wireless router known as WEP or WPA Key,,press ok.. it will attempt to connect and wil give u a message successfull..now run the software on computer and select wireless install option on computer and follow the instructions
Posted on Sep 02, 2010
Do I need a password to hook up my router?
When you plug it in, it will be enabled and wont have any security features. So you need to set up wireless security and passwords if you are using wireless. Note that you can only set it up if you are connected to it with a cable from the computer. It should have an installation CD that makes the process easy.
Sep 09, 2015 | Linksys Computers & Internet
Gateway sx2865-ur11p can't find networks
Double check the laptops wireless switch. They often have a feature that allows you to completely disable/enable the wireless aspects of a laptop. Windows will not tell you it is disabled always and just tell you it can't detect any signals.
Mar 20, 2014 | Gateway SX2865-UR11P Desktop Black
My device won't accept my router password
You may have to hook up to it with a wire to set up the wireless feature. Once it is recognized you can remove the wire and should be wireless at that point.
Feb 22, 2014 | Televison & Video
Belkin F5D7234-4 V5 MODEM LIGHT AND INTERNET LIGHT ARE BLANK. WHEN I RUN A CABLE FROM MY MODEM TOMY COMPUTER, INTERNET WORKS, BUT WHEN I CONNECT THE CABLE FROM THE MOEM TO THE BELKIN WIRELESS ROUTER, NO...
Is this a new router - or should I say did you only have the one computer hooked to the modem until now? Some ISPs use the MAC address of the installed PC to assign the network IP address. Since the Router will have a different MAC address, the modem will not recognize it. ISPs use this as security, but it makes networking impossible. However, most routers have a feature called MAC spoofing, which allows the Router to fake the modem into believing it is the computer originally attached to the modem. On newer routers this is a feature that can be automatically done during the setup wizard. You need to have the original PC hooked to one of the router ports (not WAN or INTERNET) and when the router asks you if you want to use the MAC spoof, say yes.
Oct 23, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Where can i find the wep key
Your SB5120 is not a wireless device. I think that you are confusing the cable modem with the wireless router. New modems may have a wireless feature.
I assume that your modem is hooked up to a router that has a wireless feature and you are trying to set up or re-set the WEP encryption key.
Try searching for a manual under the router name.
You can always bring the router back to its original default state by pushing the re-set button, located on the back of the device. It is usually a small hole about the size of a paper clip near the on-off button. While the router is powered on, push the point of a pen into the hole for about 10 second. Then you can go through the router menu and reset all the passwords, WEP keys and other parameters.
If you need help on how to access or set up the router menu, please comment. Also let me know if this information helped you.
J
Feb 22, 2011 | Arris SURFboard SB5120 Modem
Low signel strength
Common with single antenna routers and adsl/router boxes, i use a zoom x6 adsl with wireless and i was having similar problems , it also has a single antenna so i disabled its wireless feature and got a linksys rangebooster router dedicated to my wireless needs, has good range and its durable, Im basically suggesting that you get another wireless router with dual antennae and use that for your wireless needs, hook that up to your DLINK modem via ethernet cable and disable the dlink's wireless feature...Hope this helps..
Oct 27, 2010 | D-Link DSL-G604T Wireless Router
How do i hook this up to my laptop?
Turn on the wireless feature on your laptop ... I would tell you how but you dont mention the make or model of laptop ... and follow the instructions that will pop up on your screen.
Sep 27, 2010 | NetGear WGT624 Wireless Router
I have a BEFSR41 v2 router. Can I hook my laptop to it wirelessly?
Unfortunately this router is NOT wireless capable
but this type of Router allows you to share resources such as
computers, printers and files. A variety of security features
help to protect your data and your privacy while online.
Oct 23, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Modem
Yes you can. There would be no problem with that. You just need to change some settings depending on the wireless modem. Although most likely they could work together without the need for changes.
Jul 28, 2008 | Toshiba Satellite A135-S4527 Notebook
I have a desktop already hooked to a cable modem. If I buy an Asus eee pc 900 notebook, what do I need to do to establish the wireless connection in my home?
You would need to Purchase a Wireless Router, These are available all over and Range from $40-$150, You Dont need anything fancy, as long as it have the Wireless Feature. You will also need to configure the network but most of the Time the software,Will walk you through setting this up.
Jul 07, 2008 | Computers & Internet
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
