I have a pioneer DVD/CD receiver XV-DV303 and I played deck music through the system. However, I think it over heated and shorted, as the sound cut completely and I have not been abkle to turn it on for 2 weeks. All that seems to be working is the green timer light which flashes non-stop. Any ideas?
  • Anonymous May 20, 2009
    How do you fix it tho ????
  • 979 Answers
Output devices have failed, due to excess heat, volume level, or some type of input overload. This is not to say that the components could themselves have a fault due to internal stresses. It's shop time...accordianman
Posted on May 10, 2008
HI i have my PIONEER XV-DV77 BUT NOW ONCE I INCREASE VOLUME THE SYSTEM CUT OFF PLEASE HELP?
You may have a short in one of your speaker wires, and the receiver is protecting itself, or you may have too many speakers connected, or be trying to make the sound louder than your receive can handle.
Jun 19, 2015 | Pioneer Audio Players & Recorders
Pioneer tech support
This implies the laser in the dvd can't read your disk, and says "No disk". Try cleaning the laser first, it'll look like an led. Unplug and disassemble then use a cotton bud with isopropol alcohol, or metho. If this doesn't work, the laser may be dead and it'll just be a surround sound unit then!
Aug 10, 2014 | Pioneer Audio Players & Recorders
Pioneer XV-DV303 (DVD/CD Receiver) When playing a DVD and the sound from the film is raised, the DVD turns off and I have to start from the beginning ensuring the sound is lower.
I imagine ANY audio source would do the same if played loudly enough.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Mar 15, 2011 | Audio Players & Recorders
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
CD/DVD player won't read discs
Firstly you need to get a Lens Cleaning Kit from KMart, BigW or your countries version of a Supermarket. Use that on the DVD player and then check all your discs for dust and dirt. Clean the discs by lightly wiping from the inside to the outside in a circular motion.
Next step if that doesn't solve the problem would be to take the cover off ( ensure unit is off and unplugged from the power source) and check if the lens is not covered with dust, lint, fluff etc. If covered wipe lightly.
NEVER LOOK DIRECTLY AT THE LENS LIGHT
Feb 18, 2010 | Pioneer Televison & Video
Have got pioneer xv-dv303 dvd/cd receiver.It does not play any dvd and cd these days. I think it needs the firmware update. How can do that.
You need:
PDA w/Palm OS 3.0 or later
OmniRemote Pro V2.02 (http://www.pacificneotek.com/)
Sony Clie peg-SL10
Type in (or transfer) the memo below to your PDA.
As a memo you can import it into OmniRemote with this menu command:
Advanced-->Databases-->Import category
When done, point your PDA towards your DV-454, put OmniRemote in TV-mode and press 0 (Zero)
That's it!!
Some stores charge $35 for this! All I ask is a small donation ($1 or more if you like) to help my site!
Memo (Name: Category-TV):
Category-TV
Button name-Enter
0000 0067 0000 0000
Button name-0
0000 0069 0049 0000 0154 00AA 001E 0032 0019 003C 001E 000F 0019 000F 001E 000A 001E 0037 0014 0005 0005 000A 001E 0037 001E 000A 001E 000F 0014 003C 001E 0037 001E 0037 0014 0014 001E 0037 0014 0014 001E 0037 001E 000A 001E 000A 001E 0037 001E 0037 001E 000A 001E 000A 0019 003C 001E 000F 0014 003C 001E 0037 001E 000A 001E 000F 0014 0005 0005 0032 001E 0037 001E 000A 001E 045B 0154 00AA 001E 0032 001E 0037 001E 0037 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 0014 0014 001E 000A 001E 000F 0019 000F 001E 0037 0019 000F 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 001E 0032 001E 000F 001E 0032 001E 000F 0014 0005 0005 0037 0019 000F 001E 0037 0019 000F 0014 0005 0005 000A 001E 0037 001E 000A 001E 0037 001E 0037 0014 0465 014F 0000
Button name-7
0000 0067 0000 0000
Button name-8
0000 0067 0000 0000
Button name-9
0000 0067 0000 0000
Button name-4
0000 0067 0000 0000
Button name-5
0000 0067 0000 0000
Button name-6
0000 0067 0000 0000
Button name-1
0000 0067 0000 0000
Button name-2
0000 0067 0000 0000
Button name-3
0000 0067 0000 0000
Button name-Channel up
0000 0067 0000 0000
Button name-Channel dn
0000 0067 0000 0000
Button name-Last
0000 0067 0000 0000
Button name-Volume up
0000 0067 0000 0000
Button name-Volume dn
0000 0067 0000 0000
Button name-Mute
0000 0067 0000 0000
Button name-Power
0000 0067 0000 0000
Button name-Favorite
0000 0067 0000 000
Feb 11, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Our Pioneer Receiver VSX-312 gave us an OVERLOAD error message while trying to play a DVD and a music CD, and there is no sound. It was really hot. After it cooled off, we tried it again and it did the...
This sounds like the audio power amp has shorted which explains the heat when it failed and the cool temperature when you tried to turn it back on. Usually these recievers have a removable bottom plate that lets you access the bottom of the boards. As there are usually 4-8 transistors along a heat sink that are paired. Check them in diode scale and look for multiple values of 0 from any single transistor. If it gives you 3 or more readings of 0 then its shorted.They also may read low,around 70 or less.In which case it needs to be replaced.
Oct 31, 2009 | Pioneer VSX-D412 Receiver
Televison & Video Logo
313 people viewed this question
Top Televison & Video Experts
Electro Med Services...
