Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Dirty printout and faint words - Canon imageCLASS MF4150 All-In-One Laser Printer
    President:
  • 2,185 Answers
You might need to do a thorough maintenance cleaning on the interior part of your printer. Please see this link:
http://nlcbs.org/coworker/Canon%20imageCLASS%20MF4150/imageCLASS_MF4150_Basic_Guide_EN.pdf
go to page 10-1 as it contains illustration that could guide you on how to do it step by step.
Thank you for using FixYa.
Posted on Sep 02, 2010
Same problem ... faint printouts from a LaserJet 4L. Replaced the toner cartridge, but I don't know how long it had been sitting around. The first 5 or 10 printouts looked fine, then they started getting...
Light print outs are due to the age of the cartridge. Take the cartridge out and shake it from side to side. This assures that the toner is not clumped up and makes it flow freely.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 31, 2011 | HP LaserJet 4L Printer
Dear Sir, i have buy hp laser jet p1007 printer but it gives no quality. it gives faint print and when i give pdf file print command it give very faint print so what can i do. Thats the faint...
Hello and Welcome to FixYa!
Hmm, faint printout may occur due to so many issues, like paper quality, bad connection, bad/dirty pick-up roller, wrong settings...
To counter all these issues, writing all the text here will be difficult and will decrease the understanding quotient. So I'm attaching a link below, where you will find all the possible solutions with pictorial / graphical representations, I hope you will find it helpful and will definitely come up with some solution.
In Case you are having any issues/questions, do ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Resolving Print quality issues
Aug 09, 2010 | HP LASERJET P1006 Printer
All printout of correspondence is in small print. How do I increase the printout size?
Font type and size are usually set in the document processing application.
If it's a word .doc,you set the size in Word.
Anything you can paste to Wordpad,highlight the text and set the font size in the toolbar.
Aug 06, 2010 | HP Office Equipment & Supplies
My epson LX 300 printout... my epson LX 300 print out faint documents(faint printout).what is the problem?
hi...this is catridge problem.
the catridge may be about to finish and the mixing is not properly taking place.
the outlet from the catridge may be blocked so reqired amount of ink is not flowing out from it.
please change the catridge it wil be fine
if my answer wqas useful please rate me
Jul 13, 2010 | Epson LX-300 Matrix Printer
When i am giving a single page printout it will printout another copy of blankpage
Please open the document, There is probably a second page added to your word document.
Open the file, go to page 2, press backspace.
When you select print option, now check how many pages its showing for printout.
If its showing one page then your file is perfect now.
Nov 03, 2009 | HP Inkjet 1200dn Printer
My Epson Stylus Color 760 printer tells me there's still ink
If your ink was installed Feb. 2007, then most probably it got expired as you said you have done test prints but with faint samples.
It is advisable to install new and genuine epson ink cartridge.
Jul 24, 2009 | Office Equipment & Supplies
Photocopies are very faint on one side
The scanner mirrors are dirty.
You can try doing a shading adjustment . You press menu #1934 to enter tech mode. Then in menus under maintenance go to shading adjustment, place 5 sheets of paper on the glass and run the shading adjustment. That may help.
But the problem is the mirrors are hazy and in need of cleaning. The rear, both side covers must be removed. Then 2 screws on the back of the scanner must be removed , and the connectors unpluged from the main board. There is also one green ground wire that is attached to the frame from the scanner.
Once the scanner is removed, you have I believe 4 screws to remove and the controle panel.
You have to be very careful opening the scan head under the lamp. It is just held together with plastic tabs. Under the lamp are the mirror and lens, that must be cleaned to get your copy quality back to mormal
Apr 01, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Dirty printout and paper jams
Hi Hazel,
Sounds like it needs a maintenance kit. This will include a fuser, which should resolve the problem of the repeated horizontal lines and ghosted words. It will also cause more frequent paper jams when it needs maintenance.
A manual for installing a maintenance kit can be found online but sometimes will come with the kit. Google it anyway as it will give you an idea of the work involved.
Hope this helps!
Mar 12, 2008 | HP LaserJet 2200dn Printer
Light, Faint or Faded Copies
How is the quality when you just scan a document?
Dec 07, 2007 | Lexmark X83 All-In-One InkJet Printer
Light and broken printout and black mark on the backside
Have the service people set the machine to add toner(per pixelcount) and test run it for a day or two. If this works it means the sensor in the developer unit that tells the machine to add toner from the cartridge is bad. If that is the case replace the sensor. It sounds like the machine is not adding toner to itself. Have them also test the toner motor.
Aug 24, 2007 | Ricoh Aficio 2015 Copier
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
77 people viewed this question
old marine
old marine
