Question about NetGear DM111P DSL Modem (DM111P100FSS)
I have a netgear dm111p mod for internet access and cannot link this to the linsky router. If I put the combination together in a small network without internet connection everything works fine. the moment I plug in the RJ11 for the internet into the modem it assigns the ISP address to one of the computers and shuts out all other computers meaning that no other computer has internet access. What am I doing wrong?
sandrew
  • 2961 Answers
SOURCE: Wireless connection fails: won't assign address
As ever starting with the simplest of solutions normally works, well spotted.
Posted on Nov 28, 2006
atlasuk2007
  • 85 Answers
SOURCE: My Mdoem's ethernet and usb lights are off
assuming you using ethernet to connect the pc to the modem: how about checking your ethernetLAN card on the pc if it's integrated with the motherboard you can enable it from the bios settings if it's an expansion card it sounds like you need the most up to date driver which can be downloaded from the card manufacturer's website if you have access to internet on another pc. assuming your pc is connected to the modem via usb: reinstall the driver for the modem . another thing you can do is buy a usb to ethernet adapter which are available for under $5 on the market one end connects to the usb port on your pc and the other end is ethernet and this should work .
Posted on Aug 11, 2007
rahul26485
  • 611 Answers
SOURCE: Netgear MR314
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
click the Properties button.
button. Click the OK button again to complete the PC configuration.
Posted on Jul 08, 2008
  • 341 Answers
SOURCE: Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Posted on Nov 26, 2008
leecom72
  • 4806 Answers
SOURCE: last light on modem not working
reset the modem by removing power for a coulpe of minutes and then power it up wait a minute for the modem to reset and then try to connect to the internet
kind regards and please don't forget to rate us
Posted on Dec 11, 2008
Anyone can use my internet how do i set up security code i have netgear wireless 150 wnr1000 router how do i fix this everyone using my enternet
You need to configure your router with wireless encryption.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 01, 2013 | NetGear Computers & Internet
Wifi works and all but keeps having my two phones put the password in every half and hour. I don't have the disc for it so can't really set it up just connected it to my charter modem.
Try this please:
  1. eHow
  2. Internet
  3. Wireless Internet & Network Hardware
  4. Netgear Wireless Routers
  5. How to Access Netgear Wireless Router Settings
X Must See: Slide Shows
How to Access Netgear Wireless Router Settings Xno-user-image.gif Ryan Bauer
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
72955587_xs.jpg Wireless routers connect computers to a network without the need for network cables.
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryptionicon1.png," "Network setup details" and "Passwords" can be customized.
Other People Are Reading
Instructions
    • 1
      On a computer that is connected to the routericon1.png with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
    • 2
      Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
    • 3
      Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
Read more: How to Access Netgear Wireless Router Settings ' eHow.com http://www.ehow.com/how_4913660_access-netgear-wireless-router-settings.html#ixzz2H3QQJGxn
Jan 04, 2013 | Computers & Internet
Need to put a block on my internet
http://192.168.0.1
Jan 04, 2013 | NetGear WGR614 Wireless Router
I need to reconfigure my netgear adsl2+modem dm111p v2
first get a wired connection with router//
get into config page 192.168.1.1
username:admin
password: changeme or password
from there you can get into config page and change the settings of the router
Sep 17, 2012 | NetGear DM111P DSL Modem (DM111P100FSS)
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Nov 26, 2008 | NetGear WGR614 Wireless Router
NetGear DM111P DSL Modem (DM111P100FSS) Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
