Question about Microsoft Windows Vista Home Premium Edition for PC
PRINT SPOOLER IS MISSING FROM SERVICES. HOW DO I INSTALL IT?
  • 666 Answers
You will want to either find the disc that came with the printer or look it up by the manufacturer and model after doing that you are looking for driver software make sure you download up to date and os compatible software you should have no problems after doing so
hope this helps
Robb
Posted on Sep 21, 2010
Im not very tech minded. but i need to restart a print spooler in order to instal an epson printer
You'll need to use an administrator account to do this, click on start, go to computer right-click, choose manage, double click Services & Applications, then click on Services, highlight any one of the services then push P on your keyboard, now look for print spooler, right click and choose start.
Sep 13, 2011 | Acer Aspire 5742Z-4200 Notebook
Print spooler is not running H P Laserjet4L.How do I install my printer
go to start ..>run ...> type services.msc press enter ..... it will open the services window then go to print spooler and double click on it one more window will come there u can found a option like start click on that it will start the print spooler services .................... to start the services u must have admin rights to start the services ................... and try to install the driver ........... if ur still facing the issue please post ur comment best of luck .............
Feb 03, 2010 | HP Office Equipment & Supplies
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
Cannot get Microsoft works to open in vista
If you stop the print spooler service...that should allow Works to open up.
  1. Open Computer Management.
  2. In the console tree, click Services.
    Where?
    • Computer Management/Services and Applications/Services
  3. In the details pane, double-click Print Spooler.
  4. Do one of the following depending on the task you want to do:
    Click Stop to stop the service.
    Click Start to start the service.
  • To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
  • When you stop the Print Spooler service, it might stop other dependent services.
  • The print spooler runs under the Local Computer system account by default.
  • You can also start and stop the Print Spooler service through a command-prompt command. For more information, see Related Topics.
Mar 09, 2009 | HP Pavilion dv9000z Notebook
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have a lexmark x3550 and it says there is no spooler, and now it says there is no printer.
Method 2
Thanks, Joe
Dec 29, 2008 | Lexmark X75 All-In-One InkJet Printer
We are trying to install the HP Deskjet D2500 series printer and get the spooler problem and cannot advance please advise
Verify that that the Print spooler service, and all the services that it depends on, are correctly installed and running.
  • Double-click the Print spooler service to open its Properties window.
  • Note all of the dependent services listed, then close the Print spooler Properties window.
If any of the dependent services are missing or cannot be started, try un- installing all installed printer drivers and then reinstalling them.
Method 2
Remove all Print spooler service dependencies other than the Remote Procedure Call service.
By removing the other dependencies the Print spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
Thanks, Joe
Nov 26, 2008 | HP Office Equipment & Supplies
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Jan 08, 2008 | Dell A920 InkJet Printer
X3470 printer installation
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
  • go to start menu then run and type "services.msc" then hit enter
  • locate the Print Spooler service in the services list
  • Change turn it on  switch to Automatic mode
Try reinstall
Good Luck
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
Microsoft Windows Vista Home Premium Edition for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
