I have a Kenmore Dehumidifier Model 580.53701 that causes the circuit breaker to activate when it is connected. It is probable 8 years old. Can it be repaired for a reasonable price or should I purchase another Dehumidifier? If I should purchase another what do you recommend?
Check your electrical panel first. Is this dehumidifier on a dedicated circuit?
Posted on Sep 02, 2010
I have a Kenmore Elite Dehumidifier. Yesterday it just stopped working. When I plug it in, the panel does not light up at all, nothing, no power! Warranty ran out last month. It is 13 months old. Thanks....
Debi, before we assume there is something drastically wrong with the unit itself. Let's look at some other things that may be causing the problem.
1. Is the outlet that unit is plugged into still have power? Has a circuit breaker in you home's
Circuit Breaker Panel been tripped? If so, unplug the unit, before resetting the circuit breaker.
2. Was the water collection bucket recently removed to empty it? If so, was it reinstalled
properly? In other words, was it installed "squarely" into the holder and making contact with
the bucket safety removal switch, on the rear wall of the bucket holder? If not, this would cause
the unit not to activate.
3. Does your model have a float valve in the top of the bucket? If so, the float may be stuck in the
UP position. Which indicates to the unit, that bucket is full. If you have a float valve, jiggle the
arm of float to make sure it moves freely. And reinstall the bucket properly.
I hope all of the above helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 24, 2011 | Kenmore Dehumidifiers
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
My Haier HD601 dehumidifier keeps popping breaker
If you are blowing the breaker then you are pulling way to much current on the startup or you have a short in the unit...
either way you probably will be much better off by replacing the unit with a new one... they do not cost enough that it is worth sinking hundreds of dollars into fixing an old one...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 03, 2010 | Haier HD601 Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Lamp(60watt bulb) dims slightly when dehumidifier starts up. The dehumidifier outlet is downstream of the lamp outlet. This dehum draws 5 amps at steady run, not sure what it's pulling at startup. Wiring...
The dimming is probably normal, especially if the motor is a split winding type that has a start and a run winding. Ususlly, it will use a capacitor also. You can view the wiring diagram to see if this is the case.
Aug 12, 2009 | Kenmore 53701 Dehumidifier
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Aug 18, 2008 | Kenmore 54701 Dehumidifier
Help me fix my dehumidifier
What else is on the same circuit? Have you added any other appliances on that same circuit that were not on it before?
If no>>>you probably have a short in the unit, and it is grounding out>>>tripping the breaker before it starts a fire.
Also, check the breaker, they can go bad.
Jul 23, 2008 | Kenmore 53509 Dehumidifier
Trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Oct 17, 2007 | Goldstar DH504EL Dehumidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
