Question about Sony Televison & Video
Tv code for sony model number KD-28DX51U - Sony Televison & Video
Sony kd-36xs955 Turn tv on all channels fuzzy,once warmed up,everything is good.Now when you try to use the hdmi port for PS3 nothing there.The tv has had problems before like it would shut off and blink...
Count how many times the standby light blinks at one time. These blinking are fault indication. You can get an idea about the faulty circuit part inside, from these number of blinks. After make it sure, if you wish to get more details about Blinking Codes to Sony TV sets, check this link.
Feb 16, 2013 | Sony FD Trinitron KD-36XS955 36" TV
My fd trintron wega (kd-0xs955) will sound as if it is starting of when POWER is pressed then the red stand by blinks a few times and nothing else when it is just plugged into the wall (no cable connected)
The flashing light is "Code" for diagnostics. Count the flashes before it pauses. Some Sony user manuals will have the answer in the troubleshooting section of the manual. If you don't have your manual,
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KD30XS955
That's the link.
Hope this helps
Jun 01, 2011 | Sony FD Trinitron KD-30XS955 30" TV
Number FBT
Hello
Number of Horizontal Output Transformer [ FBT OR LOT] for SONY FD TRINITRON KD-XBR960 is,
1-437-523-61
OK
Jan 24, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
Sep 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Sony digital tv KD 32DX40U wont pick up digital signal
The tv is a 2k model - I have the same one, digital is now 8k so it won't work digitally anymore.
2K Equipment
  • All 2K-only products will stop working with the introduction of the 8K transmission mode at switchover.
  • 2K-only set-top boxes cannot be upgraded, but 2K-only IDTVs can be updated by adding a current set-top box or digital TV recorder.
  • A full list of affected models is on the Digital UK website at www.digitaluk.co.uk/2kequipment.
Jul 08, 2009 | Sony Televison & Video
Sony tv manual
go to http://safemanuals.com/user-guide-instructions-owner-manual/SONY/KD-32DX40U-_E (hope this helps) click on download user guide. any help with this call felton (870)733-1375 or email me IWHYOU@YAHOO.COM
Dec 28, 2008 | Televison & Video
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
