Question about Whirlpool LBR8543 Top Load Washer
Whirlpool top loading washing machine LBR8543 makes a squealing noise when running.
  • skelshon Sep 02, 2010
    Hi
    Thanks for that. Forgot to mention that I recently sold the machine (on Ebay.co.uk) and it was transported (shipped I think you call it) by road 200 miles by the buyer in the back of his van, after which the squealing started. He took just as it was with no protection.
    Only time will tell if the information solves the problem. At least I know what to check.
  • Whirlpool Master
  • 17,130 Answers
The noise can be the motor generating the noise or the rubbing of the moving parts, the belt, the spindle bearings or the tub by itselt.
Now I am assuming all these could be the possibilities and I would like you to very the source of the noise that is coming out. You will need to look from the bottom of the washer with a good lighting, jack up the washer and while it runs carefully look on . I can be any of the above or a related one.
Once you ahve detected the noise source, shut off the machine and drain off, the lay it on the side to have an opne view. manually look for the sqeaking noise with the rotation of the motor or the tub.
You use good degreasing and oiling of the part that is contributing to the noise. However if it is with the motor, then it must be taken out and serviced. Also if the tub bearings can be another issue.
Check also if any plastics or metal is rubbing with the vibration
of the movement.
Posted on Sep 02, 2010
  • Donald DCruz
    Donald DCruz Sep 02, 2010
    Thanks but You have forgotten to rate me.please vote
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why does this top load washing machine squeal when running?
This could be a case of bad bearings and if it is you will need a service company to fix.
Aug 02, 2015 | Whirlpool Calypso GVW9959K Top Load Washer
What causes this machine to squeal while running?
I had a similar issue, had a bad bearing. A quite frequent failure int this device. Only way to diagnose is dismounting it
These are not properly your model but see some videos how to do it:; might help to understand the job
How to Replace Washing Machine Bearings
Repair HE3 Washing Machine Bearing Noise
ApplianceRepairVBlog 2 Replacing the rear bearing on Whirlpool Duet...
Duet Whirlpool Sport Changing Bearings
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Motor noise
while running,the main culprit is usually worn motor bearings.To check the
motor bearings,remove the belt and run the motor by itself,listening for the
noise.If it makes the noise,than the problem is most likely the result of worn motor bearings.
Apr 08, 2010 | Whirlpool Washing Machines
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Squealing noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Howling or squealing noise when the machine is filling with water
there is a restriction in the valve assembly. it is servicable so remove it, open it up on both hot and cold and clean thoroughly. replace and test
Jul 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Jun 20, 2007 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool LBR8543 Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
