Question about Frigidaire PLEF398AC Electric Kitchen Range
Frigidaire stove door locked - Frigidaire PLEF398AC Electric Kitchen Range
  • 1 more comment
  • Anonymous Feb 01, 2009
    Can't get the cleaning process to stop and open the oven door?
  • Anonymous Feb 07, 2009
    The stove got locked and I cannot unlocked or turn on the oven.
  • Anonymous Mar 22, 2009
    What does the lock assembly look like and how do I unlock it?
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
Posted on Jun 06, 2009
Frigidaire stove door is locked to be cleaned but the door is ajar and the cleaning is not happening either. Should I just wait for three hours to end and then it will unlock. Or, do I need to do something to get it unlocked.
Thank you, Robin
Posted on Sep 14, 2008
My door remained locked for several hours after the Oven Cleaning cycle was complete. As mentioned by RMclellans solution,I pushed in on the right side of the door for 20 seconds and it unlocked. Seems the door switch is slightly out of adjustment. Thanks RMclellan!
Posted on Jan 02, 2014
How do I put the stove door back on? I cannot put the door back on.
Posted on Jul 05, 2009
    Scholar:
  • 150 Answers
Stuck in lock after self clean maybe? the lock assembly is in the back. you can open up the back to get to it and get the unit open.
Posted on May 10, 2008
4 Suggested Answers
SOURCE: I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Posted on Jan 15, 2009
  • 111 Answers
SOURCE: Frigidair Electric stove (MN) CFEF358EC
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Posted on Jun 17, 2009
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
How do I lock my Frigidaire stove model 37BAW*5 door
Thank you for your inquiry, longbowshoot!
I see that you would like to lock the door on your Frigidaire range. Normally, the oven door will lock once the self-clean cycle has been started. The model number you have provided 37BAW*5 is not pulling up as a valid model number. Are you attempting to lock your control panel? If so I need your model number to further review steps on locking your door. You can locate the serial tag (which lists your model number) behind the lower drawer of your range. I look forward to assisting you. -Matt
Dec 07, 2014 | Frigidaire Kitchen Ranges
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
I have a Frigidaire Professional Series Stove. My red lock light will not go off. When I came down stairs it was on. I locked it & unlocked it and it's still on and my stove will not come on.
I looked up your model number and I would suspect a faulty door lock latch motor switch, part # 316464301.
It can be located my removing the back panel of the stove.
Aug 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
Nov 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven door locked and stove wont work turned the oven on to self clean and it just blew cold air.It did not clean and now the door will not open Please help.
I woke up one morning recently with the oven door on "locked." The stove works, but the oven door will not open. As far as I know, nothing in the oven works. The "door" sign shows up on the window where the clock is.
Sep 19, 2008 | Frigidaire FEF336BC Electric Kitchen Range
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
1,882 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
