Question about ASUS Computers & Internet
MY ITUNES KEEPS FREEZING RUNNING ASUS M3NHD/HDMI BOARD WITH WINDOWS 7 PROFESSIONAL AMD PHENOM 9750 PROCESSOR WITH 4 GIG DDR2 RAM. DEVICE MANAGER SHOWS COPROCESSOR AND MULTIMEDIA DRIVER NOT FUNCTIONING CORRECTLY ????? HELP
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 56 Answers
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
I have a new AMD Phenom X4 9750 quad core processor with a new MSI 785GTM-45 motherboard and a aluminum CPU cooler fan 95 watt. when I try running the system it won't stay on for more than 45 seconds. I...
It is possible that the processor may be defective but that is very rare. Take the processor off of the motherboard and reseat it. Make sure that you are using thermal paste(preferably aluminum) properly. The motherboard has a function in it that if the processor overheats it will shut the computer down to prevent damage. Also check to make sure that you RAM is fully seated and also that it is compatible with your motherboard. I have seen several instances where the RAM was not compatible with the motherboard and the computer will not boot.
Mar 11, 2011 | AMD Phenom X4 9750 Quad Core Processor...
M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
Feb 12, 2011 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
ASUS M3N78-VM motherboard Problemes
Good Motherboard...BTW... Reset BIOS to Factory defaults. Make sure you have the latest BIOS as well. Then you need to eliminate the other devices. Try running just on the On-Board Video...see if crashes. Run w 2 Gig Ram...same same... and of course the processor which may be impossible. Once you know it is MB or CPU... you make a choice which to buy or test. MB first... you can always return with less stress.
Dec 31, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Umm the info on one of my appliances is wrong and have no ide a how to edit iton this website by the way it's a 3 gig ddr2 about to be a 4 gig apparently that's the max the motherboard will allow even...
If you have a 32 bit version of Windows dont put in 4 gigs. The Motherboard may support it but a 32 Bit version of Windows will only support a total of 4 gigs of ram including the video memory, cache, and pci. If its a 32 bit I normally recommend no more than 3.5 gigs of ram memory. Normally its safer to run 3 gigs. Windows may not run well if you go past that 4 gig point. As far as the appliances problem your refering to I didnt understand what you were asking for.
Hope this helps keep you from having a ram issue.
If you need help with the other question please be more specific. Thanks...
Sep 23, 2009 | Gateway GT5453E Refurbished AMD Desktop...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
I installed a AMD Phenom(tm) 9950 Quad-Core Processor which runs at a speed of 2.6 ghz but windows xp pro is only reading it at 1.3 ghz. I also have 4 gigs of ram but windows xp is only reading 2.75. The...
There seems to be some sort of incompatibility issue between your motherboard and the Phenom, or maybe some option is not enabled in the motherboard bios that windows is only sensing half of the GHz, like if the processor is only running 2 cores instead of 4.
About the memory diference, that same problem is because the 64bit difference. Unless you have a 64bit XP you won't see the full 4GB. Windows XP is limited to 3 or 3.5GB of ram it can use, you are showing 2.75 maybe because some video board is integrated in your motherboard and it may be borrowing an extra 0.25GB from the 3GB that are usable under windows XP 32bit OS.
Please comment what motherboard you have, since the cpu alone can't be blamed nor configured.
Jan 03, 2009 | AMD Phenom X4 9750 Quad Core Processor...
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Computers & Internet Logo
137 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
