Question about Ryobi Thickness Planer Blades
Planed board has a lower step than the rest of the board after passing thru planer , not equal amount planed off.
  • 843 Answers
I think you are talking about what is commonly called "snipe". This is an inherent problem with all planers, but especially with heavier cuts. You can take lighter cuts, or you can start with a board longer than your intended finish length. You can also put the board you are planing on top of a longer board, then feeding them through together.
Posted on Sep 02, 2010
One end of board is thinner than the other end when plained board is done
This is after running it over a jointer? That's not uncommon. Flip the board after every pass to help keep it from happening.
If this is after running it through a thickness planer, are you sure you're not just seeing snipe? If it's not snipe, then the planer's elevation adjustment is somehow slipping or working its way into another position as you plane.
It'd help if we knew which machine you're talking about.
If you're hand-planing, then you'll need to work a bit on technique... practice on cheap softwoods.
Jan 03, 2014 | Crafts & Hobbies
Table on jet planer will not lower and board is stuck
Unplug the machine, and rotate the motor backwards. Look at the cutter to determine you are going backwards. Eventually things will free up, but it will take a while. Then clean out everything real good, and keep it clean. Consider a shop vac hooked up to a discharge if it has one.
Nov 25, 2013 | Jet JPM-13CS, 13" Closed Stand Planer /...
Severe sniping with planer
You will always have snipe at the end of planed boards equal to the distance from your infeed and outfeed rollers. It's severity is determined by how much the board sags or dropps behind the planer until the second roller catches the board. Some planers have extended tables to help with this. What you can do is hold the board up as much as possible and still let the infeed roller move the board smoothly until the board contacts the outfeed roller.
Jan 30, 2013 | Craftsman 12 amp 12-1/2" Bench Planer...
WHEN PLAINING A BOARD IS COMING OUT WITH A UNEVEN PLAINING ON THE ENDS OF THE BOARDS ABOUT 3" TO 4" FROM THE EANDS.
this is normal with all planers, when you feed the board in the planer there are two feed roller one on each side of the knives so you get uneven pressure on the board at the start and at the end of the board .when planing boards for a project always add 10"inches or more extras then cut to lenght after planing to thickness required. never cut boards to length before planing .
Apr 11, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
I have a delta 12 1/2'' portable bench top planer, I am having feed problems with the machine. It really has not fed lumber thru it since i purchased it, Can you give me some advise on what to do make it...
Hi David, W/D here.
You have already covered the normal bases, so give this a try. When planing, cut considerably less, and see if the feed improves. It should. You should probably try this on scrap wood to get the feel of it. Measure your wood, then aim to plane no more than 1/16" on the first pass. If successful, try a bit more, say 1/8". Generally speaking, it is better to make multiple passes taking small amounts of material than to try to get it all in one pass. The wood will feed better, with less checking, and give you a better finished product.
Best regards, --W/D--
Feb 19, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
Boards are difficult to get through the planer.
you may just need to wax the bottom plate of the planer. Either by rubbing with solid candle wax or maybe applieing household furniture wax paste.
Jun 06, 2010 | Tools & Hardware - Others
Power planer
The gouge in the beginning is either from the planer being set too deep or holding too much
hand pressure on the back end of the tool. Try
more pressure on the front end when you first hit the door and then pressure the back end as you leave the door. You will need to experiment to find just the right pressure points. On the final passes sight the door for straightness and fix any unevenness in the door. You can also try real shallow passes since this makes finding the pressure points
much easier. Also the planer should be set at
a 1 or 2° bevel away from the **** mortises so
that the door is not hinge bound when closing it. When the bevel is set, it is a little harder to
gouge the door because the initial passes are only hitting or kissing the back end of the door.
I hope this helps.
Apr 07, 2009 | Sheffield Hangzhou #532606 3" Adjustable...
Ryobi planer won't pull wood through, Sometimes pushing/pulling helps.
I have this planer and what I have found is first clean the rollers with naptha on a rag be VERY CAREFUL plug machine in kick on and off un plug machine clean exposed part of roller then plug in and kick on again to move rollers, after that clean in feed and out feed tables then wax with hard wax and polish and wood should feed thru much better.
Feb 18, 2009 | Tools & Hardware - Others
Planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Nov 13, 2008 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Planes Comparison
If you have a stack of hand planers and you do a lot of woodworking, you might want to buy a power planer. Power planer have a number of qualities that should convince you to keep the old hand planers but add that power to the group. Choose a power planer when you have a lot of planing to do. One thing about a power planer is that it is much faster compared to the hand planer. Use a power planer when you need to make rabbets or even scrolling. The power planer can do both of these jobs. There is a great deal of versatility about a power planer. Keep the cut smooth with a power planer. Frequently a hand planer needs to be lifted and started again. This leaves gouges and groves. A power planer has a continuous blade that leaves a smoother cut. Get more precision. The continuous motion of the hand held power planer and set depth cuts the specific amount that you want. Plane larger areas. You can plane doors quickly and easily with a few strokes of the power planer. Straighten a board easier with a power planer. You also can create chamfered surfaces with the power planer.
Aug 27, 2008 | Rockler Carbide-Tipped Radius Plane &...
Ryobi Thickness Planer Blades Logo
273 people viewed this question
Top Ryobi Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Ryobi Masonry Tool Expert? Answer questions, earn points and help others
