Question about Refrigerators
Hello there my fridge drain hole at the back of the inside of the fridge keeps freezeing up blocking the hole with ice any ideas?
  • 4,793 Answers
Syringe out drain with neat clorine bleach.(smell will go in 30 mins)and cover all food with clingfilm........to cut down on condensation..
nice sunny day in england.....
Posted on Sep 02, 2010
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
My bottom freezing compartment some how gets water in it and then it freezes what could be the problem?
Hello
The water comes from the self defrost cycle.It is supposed to drain out to a collector under fridge.
Sounds like your drain got clogged causing ice block to form.
Turn off fridge and use hairdryer to melt ice block. You should be able to see a drain hole.Continue to melt using Hair dryer and hot water.Once ice is out of drain tube use some flexitube to gently push out any obstruction(usuually a pea or lima bean!)
Good as new.
Any feedback much appreciated
Jul 28, 2011 | Kenmore Refrigerators
Water is collecting on the top shelf & in the bottom of the refrigerator. Water is clear. Water at bottom will partially freeze. Cleaned the coils & made sure all vents were unblocked. Problem...
if you have water leaking down from the freezer into the fridge you have a blocked drain in the freezer,if you pulled off the back inside wall of the freezer and melted the ice off of the coil you should have noticed that the water wasn't draining down the drain hole under the coil.pull off the back inside wall of the freezer,look under the coil and you'll see a drain hole,when the freezer defrosts the ice melts and goes into the drain hole and down into the pan at the bottom of the fridge where the compressor is and it evaporates,your drain is blocked and the water is draining into the fridge section.unplug it,melt out any ice with a hair dryer,now you have to clear the drain line,i use a steemer to do this,it blows steem down into the drain and cleans it out in no time but if you don't have a steemer you need something that will push air down into the hole like a turkey baster or even a shop vac,pull off the hose and stick it into the other hole and then you can blow through the drain line with it,when you think the line is clear pour hot water into the hole,if it drains through your done,if not keep hitting it,also if you open the fridge door and with the hair dryer heat up the middle ceiling in the back,that's also part of the drain,in the middle of the ceiling and back wall where they meet,heat it up for around 5 minutes and then try the water,it will clear out,it could take around an hour or so to do it.
Jul 08, 2011 | Kenmore Top Freezer Refrigerator
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
if it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
May 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidare Mod.FRS26H5AS Leaking water into bottom of freezer where it freezes then leaks out door
I had the same issue.. I checked this web site and found the solution (on another post).. It was the drain of the fridge being blocked.. I didn't know the existence of such drain.. it turned out that it got blocked with some dust, therefore with every defrost cycle, the water was not going down to the evaporator tray, then going inside the fridge (eventually freezing), then overflowing to the outside doors.. Check on youtube for videos on how to open the fridge and clean this drain.. Have fun..
Feb 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Fridge that is leaking
Remove the back panel of the freezer . Use a hairdryer on the drain (aluminum enclosure) to defrost the ice .Once you see the drain hole , keep defrosting hole until only water in the hole . Use a small hose and blow into the hole to blow out any debris . Using an aluminum fence post holder about 6" long , put into hole and wrap about 1" around the calrod heater . This will transfer heat to the hole to keep it from freezing up .
Jul 06, 2009 | Refrigerators
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
