Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
Not cleaning contents on upper tray - Tricity Bendix 24 in. DH102 Free-standing Dishwasher
  • Tricity Bendix Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 02, 2010
What is the latest software version
Magellan® RoadMate® 1700 Software Update - Installation Instructions
To install this software update you will need to install Content Manager.
Content Manager is a computer application that syncs with your Magellan GPS navigator to deliver new map updates and product information. To update your GPS download content manager and follow the steps below.
  1. Download and install Content Manager on your Computer
  2. Turn on your GPS. Wait for the menu to appear and connect to your Computer using the USB cable provided.
  3. Content manager will automatically prompt you about the update. If Content Manager does not prompt you, right click on the Content Manager icon located in the system tray (on a Windows based pc) or click on the Content Manager icon in the Menu Bar (on a Mac) and select "Check for updates now". Content Manager will inform you if you have the latest software already installed.
NOTE: System tray is in the lower right hand corner of your computer monitor screen near the clock on a Windows based PC. The Menu Bar is the upper right hand corner of the computer monitor on a Mac
Apr 05, 2015 | Magellan Roadmate 1700
Kerig Vue will not come out of the preheat mode
This worked for me: 1) Turn off machine 2) Remove lower tray. It pulls right out. make sure it is clean. RE-insert. 3) Remove upper tray. It's a little trickier, put it also pulls down and out. Mine was full of coffee grounds. I rinsed it out with tap water. 4) Replace upper tray. 5) Take a used V-cup and take the foil and filter out leaving only the plastic tray. Clean it thoroughly of coffee grounds with water. Replace it in the V-cup insert. 6) Power on the Vue. It should come on pretty quick and say " Ready to Brew" run 6 to 8 oz through with just the blank V-cup. This will clean out any remaining debris. 7) Now put in a new V-cup and brew your coffee!
Oct 04, 2012 | Keurig Vue Brewing System
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Dec 30, 2010 | Asko 24 in. D3350 Dishwasher
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Jul 06, 2010 | iRobot Roomba 530 Robotic Vacuum
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher.not cleaning top tray
Make sure your upper fan is turning manually. then check your water pump. to make sure it's pushing water up there. Also make sure you're not overloading the bottom where the rotating fins can't get around.
Sep 23, 2009 | Dishwashers
Phaser 8200
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Jul 17, 2008 | Xerox Phaser 8200 Laser Printer
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
123 people viewed this question
Top Tricity Bendix Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
