Question about Canon imageRUNNER C3200 Copier
HI THE MACHINE HAVE THE ERROR :E000020-03b0.IT'S THE CYAN DRUM THET NEEDS REPLACEMENT.CAN I REPLACE ONLY THE DRUM,NOT ALL THE UNIT,OR REESET WITH A CHIP?
  • 170 Answers
Yes you can replace only drum bur you need to replace also the drum cleaning blade
Posted on Sep 03, 2010
E0000-20-0360
This could be a DC controller issue or and issue with the black drum unit. If you have replaced the Black Drum, and it still produces the same error after doing a print, then you will need to replace the DC controller PCB and possibly look at the power supply.
Sep 18, 2012 | Canon for IMAGERUNNER C2020 C2050 C2058...
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
Please what can I do to work the machine that says fatal error 133;
133 relates to the cyan LED sensor, infact most likey it is the actual Cyan Image drum.
make suer the LED above the Cyan drum is clean, and freely mounted in the spring assembly.
remove and re instal the image drum..
if that does not work, most likely u need a new image drum,Cyan..i bet it is low and due soon for replacement...
good luck
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Canon IR C3200--error code E000020-01b0 explain this code please
Hi there
Error code E000020-01B0
That code relates to the yellow drum unit.
The unit was probably damaged taking it in an out.
Needs to be replaced.
Or try.
1. Information UPDATE UPDATE - the Drum units are as follows:
Yellow - 746
magenta - 215
Cyan - 758
Black - 9
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 04, 2010 | Canon imageRUNNER C3200 Color Printer
Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Brother MFC-9840CDW. Print unable 29 error message. What do I do???
I got this error today. After examining the drum unit I saw one of the 4 drums (cyan) had a strip of sticky plastic wrapped around it, preventing it from turning easily. The plastic was from the drum unit itself. It held the cyan wiper pad in place. My drum unit needs to be replaced after 3300 pages. It was supposed to last for 17,000.
I have pulled out the color toners and am using it with only black until I get a replacement.
Jan 14, 2009 | Office Equipment & Supplies
380 Paper Jam Error just before blue toner is laid down
It sounds like the problem is with cyan drum, drum cover broken?, The fix I'd follow without looking is replace cyan drum (or possible remove drum cover completely if broken) but it could also less likely be the Transport Unit aka "shinny" it just clicks out too for inspection
Keep fingers off drum's and trans unit surface.
Service manual is japanesse english limited stuff, trust me they are not much help, try the user manual it at least has the names of stuff. User manual is on disc that comes with printer or via download from oki's web support page.
Feel free to post back
S.
Dec 28, 2007 | OKI C5200n Laser Printer
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
703 people viewed this question
old marine
old marine
