Question about Minolta EP1030/1030F CS/PRO Copier
Describe your how can I fix minolta cspro ep 1054 Problem ? My copier machine is not running now, due to system lock cause the imaging drum had reach 60,000 copies already and since it still produces a nice copies, I need the bypassed word in order to make the machine run and and use the same old imaging drum again. please help, Thank you.
  • Minolta Master
  • 19,396 Answers
Hi.
If you want to attempt resetting the counter enter in service mode and do a Timer Reset.
If you have replaced the drum (or if you need to replace it), then you have to perform the auto image density control procedure.
To reset the meter count:
enter service mode: stop, 0, 0, stop, 0,1, find meter count and reset. This should be done by pressing "1" to access meter count, then press"8" to display counter on the zoom display.
Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.When you see E in the display, press 5 and the copy(start) button to perform the auto image density control procedure.
Posted on Sep 02, 2010
How do i solve my minolta copier cspro ep 1054 printing blank document
check the transfer wire assy. located under the drum. might not have a good connection or the High Voltage unit is bad. That is a very old machine.
Apr 03, 2017 | Minolta Office Equipment & Supplies
Minolta EL 1054 giving drum sign how can I reset please give me the simulation
first replace the drum, then clear the counter, machine works off the counter, clearing the counter without a new drum will have the machine set voltages to certain assembly according to what a new drums needs when in fact it is old causing image problems. to reset go to service mode stop 0 stop 01
Mar 14, 2015 | Minolta Office Equipment & Supplies
How to Fix Error c 05 Minolta ep 1054
Open up the machine, near the heater section, there is a push button on the circuit board.Press it, machine will restart and code is removed.
Feb 07, 2015 | Konica Minolta Office Equipment & Supplies
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
Minolta EP 1054 - need to change the cleaning blade
Hi, I have all spare Minolta EP 1054 copie.But quistion Where you live? If you live in Bangladesh.I will give you.But if you live another country you send money I send it by DHL.Please contact us xptareq2000@yahoo.com or call 08801819879575.
Jul 26, 2011 | Minolta EP1030/1030F CS/PRO Copier
Ink fall in down inside minolta cs pro ep 1054
Get the developer replaced. and developer unit cleaned. Have a Konica Minolta tech come out and clean the entire machine replace the required parts such as Developer, clear the counters and run the required F8
Oct 31, 2010 | Minolta EP1083 CS/PRO Copier
There are black spots and lines on my paper when I
Clean the optical section(mirrors,lens,glass).Remove tje IU unit,change the OPC drum cleaning blade and clean the drum,charge corona and transfer/separator corona,after perform F5.
Sep 25, 2009 | Minolta Office Equipment & Supplies
Please help
It means that the maintenance counter has reached its limit or you may have an error. If it is time for maint. then usually you replace the drum, cleaning blade, and developer (or the entire process unit) and reset the counters in service mode if the parts do not reset the counts automatically. Or you could simply reset the codes and not preform any replacements. Could you provide a bit more detail on the exact model number (EP-2010, EP-2030, etc...) and such and I can provide you more information on how to rectify the situation.
Jan 14, 2008 | Office Equipment & Supplies
3,108 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
