Question about HP PSC 1210 All-In-One InkJet Printer
Printer showing "check print cartridge" can't clear
  • lpayne_home Sep 02, 2010
    unit was printing fine then error accured
    have tried cleaning both heads to luck
    hate to buy new cartridge if printer heads are at fault
    any suggestions
  • 55 Answers
Sometimes, the cartridge head gets damaged due to touching or cleaning manually with something,so the printer head will not recognise it even if there is enough ink in it.Try using another cartridge & see if it works or not.If not,your printer,print head might be dirty or faulty...for dirty clean it with a cotton swab with a cleaning solution very carefully.Faulty heads are costly to repair..I am afraid..
Posted on Sep 02, 2010
  • 3 Answers
Printer motor is not working
Posted on Jan 31, 2011
  • 67 Answers
Even after cleaning the print heads if the soln, persists, then you will have to change the print head.
Posted on Sep 03, 2010
Installed a new cartridge and no imaging is printing on photo paper
Sounds like Blocked Nozzle heads assuming its making the correct noises when press "print" If Not
First ensure connected correctly:
Control panel / Devices and printers / select printer ( make sure its the default printer) right click on printer properties : Print test page.
Next repeat but right click Printing Preferences / maintenance / Nozzle check then Head cleaning.
This generally works with printers used fairly regularly.
Where printers left for long periods may have to resort to removing offending cartridge/s and using a syringe with warm water and flexible tubing to clear blocked print head (gently !) Kitchen towel underneath the print head will show when ink / water is clear. Usually have to replace with new cartridges :Then use nozzle check.
May 14, 2016 | Epson PictureMate 500 InkJet Photo Printer
I have an HP Photosmart C4180 all-in-one. I have never been able to get it to print. I have just spent several hours over two days with no luck! It prints but nothing shows on the paper. I have...
Remove the the cartridges.Just touch the print head in a soft tissue. Try make a line in tissue.If the line not come u should change the cartridges. becos print head getting dry.If this ink come out there error for printer.
If your cartridges is dry it clear a refilling technisian.May they having machine clear this problem.
ooooooooook dear,inform me
Jun 17, 2011 | HP Photosmart C4180 All-In-One InkJet...
It shows "remove any obstruction
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
May 27, 2011 | Lexmark X4650 InkJet Printer
10.00.00 supply memory error
The 10.00.00 SUPPLIES MEMORY ERROR is based on the e-label. To clear the error, do the following:
NOTE: If the error occurs, it should appear at beginning of life, causing the error message after first installing the cartridge.
Turn the printer off and on to clear the message.
Put in the old catridge and see what happens.
If OK put in the new one again.
Verify that the print cartridge is a genuine HP cartridge.
Check that the E-label reader is functioning correctly.
Check that there is contact between the E-label chip on the print cartridge and the E-label reader on the printer.
To verify this contact, insert a new print cartridge.
Remove it again.
Check for scratches on the e-label chip and on the cartridge.
If contact is being made, replace the print cartridge (part number: Q2610A).
If contact is not being made, check the toner guides to see if they are in the proper position, or that the cartridge is not damaged.
If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
Turn the printer on again.
If the error does not clear, turn the printer off and remove tray 3.
Turn the printer on and verify if the error clears.
HP has recently discovered that a 10.00.00 Supplies Memory Error can occur when Tray 3 is faulty.
May 06, 2010 | HP LaserJet 2420 Printer
My lexmark x5630 has been showing paper jam but there is nothing inside the printer thats stoping it please help.
Hello. Try removing all sheets of paper from the printer. Make sure to check in the feeder by peeking inside it. Clear any foreign objects. Open the printer cover, and remove the cartridges. Clear any foreign objects around the cartridge carrier. Close the printer cover without the cartridges. Unplug the printer from the power outlet. Plug the power back after 10-15 seconds. It should power on automatically. When printer asks for the cartridges, load them back in. Close the cover down. Printer will print an alignment page. Just let it finish print the page. When there's no more error, try to make a copy or print from the computer to check. Hope this helps.
Mar 09, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cartridge Stalls
hmmm...not too good on this one. Seems that maybe there's some paper jamming the runners or mechanism under the head carrier. Check that first, but be careful, since it's delicate under there
Feb 06, 2008 | Dell A940 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
1,018 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
