CD burning Files won't copy to temporary file, error message : windows experiencing problem copying file
  • 24 Answers
Is the Temporary file full with .tmp files? If so Windows can not accept the files from the Burner. Also make sure in your Burner Options that you have Checked the Option to Write Files to the Windows Tmp Directory, also check the file path and make sure that is is directing the burner files to the correct area.
Posted on May 10, 2008
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
How do I copy a data CD?
jax0696,
Below are the steps to make a data disc.
Step 1
Insert the CD you wish to copy in your CD/DVD drive.
Step 2
Click "Open folder to view files using Windows Explorer" on the AutoPlay pop-up.
Step 3
Click anywhere in the right-hand panel and press "Ctrl" and "A" to select all the files and folders.
Step 4
Press "Ctrl" and "C" to mark all files for copying.
Step 5
Click "Desktop" at the top of the left-hand folder tree.
Step 6
Click "New folder" at the top of the window. Type "TEMP," and press "Enter" twice to rename and access the folder.
Step 7
Press "Ctrl" and "V" to copy the CD to this temporary location.
Step 8
Eject the data CD when copying is completed and insert a blank recordable CD.
Step 9
Press "Ctrl" and "A" to select all files in the "TEMP" folder. Click any file and drag them on top of your CD burner in the left-hand panel.
Step 10
Click "With a CD/DVD player" in the "Burn a Disk" dialog box that pops up. Click "Next."
Step 11
Right-click the CD burner and select "Burn to disc."
Step 12
Enter a disc title or keep the default one. Click "Next" to copy the files.
Step 13
Right-click the "TEMP" folder, hold the "Shift" key and select "Delete" to remove temporary files and bypass the Recycle Bin.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 20, 2013 | Dell Studio Hybrid Desktop Computer
Copy or drag to CD give a error message
What is the error messege?
One thing that can cause a failed CD burn is the IMG file in a user's temp file.
Left click Start - Left click Run
Type %temp% and hit enter
Find a file that will have img_1 on it
This is the file that windows uses to burn files on your CD - it acts like an image place holder. Right click on it and delete that and see if that resolves the issue
Dec 24, 2009 | Microsoft Windows XP Professional for PC
Icannot copy to cd/dvd. i have tried various different discs. but file will not fit error re occuring. help
If am correct , You are trying to copy a disk....
Normally we get this, when there is space problem.
The software you are using if Nero.. it uses a temporary caching files on your local hdd in my documents.
Try to free some space and see to it
Also If you using and external dvd-rw, you will need to see if the things you are trying to burn can be cached via usb . Normally when burning more than 7gbor more you get this error, Or else use an internal drive to burn the same
hope this may help you
regards
uttam
Dec 18, 2009 | Microsoft Windows XP Home Edition
I don't know how to back up my files onto a cd. Can anybody help.
With Windows XP and a CD-recordable (CD–R) or CD–rewriteable (CD-RW) drive, you can copy data to a CD as easily as you used to copy to a floppy disk.
To copy files and folders to a CD
1.
Insert a blank, writable CD into the CD recorder.
2.
Open My Computer.
3.
Click the files or folders you want to copy to the CD. To select more than one file, hold down the CTRL key while you click the files you want. Then, under File and Folder Tasks, click Copy this file,Copy this folder, or Copy the selected items.
If the files are located in My Pictures, under Picture Tasks, click Copy to CD or Copy all items to CD, and then skip to step 5.
4.
In the Copy Items dialog box, click the CD recording drive, and then click Copy.
5.
In My Computer, double–click the CD recording drive. Windows displays a temporary area where the files are held before they are copied to the CD. Verify that the files and folders that you intend to copy to the CD appear under Files Ready to be Written to the CD.
6.
Under CD Writing Tasks, click Write these files to CD. Windows displays the CD Writing Wizard. Follow the instructions in the wizard.
Notes:
• Do not copy more files to the CD than it will hold. Standard CDs hold up to 650 megabytes (MB). High–capacity CDs hold up to 850 MB.
• Be sure that you have enough disk space on your hard disk to store the temporary files that are created during the CD writing process. For a standard CD, Windows reserves up to 700 MB of the available free space. For a high–capacity CD, Windows reserves up to 1 gigabyte (GB) of the available free space.
• After you copy files or folders to the CD, it is useful to view the CD to confirm that the files are copied. For more information, click Related Topics.
Jun 27, 2009 | Microsoft Windows XP Home Edition
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
Problems copying a folder
eject the cd/dvd from cd-room and start copying .. when copy is finished put cd/dvd in cd-room and write these files to cd
all above actions done without any prgrams with Xp sp2
regards
zoser
Oct 20, 2008 | Microsoft Windows XP Home Edition
How do you burn a cd on the travelmate 290 ?
Windows XP CD Copy Windows XP has CD-Recordable (CD-R) disc burning support for most CD writers.
8b118c9.gif First set your CD-recording options:
  • Open "My Computer"
  • Right-click your CD-R drive and select "Properties". See figure BK-1.
  • Select the "Recording" tab (if this tab isn't available, your device doesn't support CD burning).
  • Check the box to "Enable CD recording on this drive".
  • Select the drive to hold the temporary files (before the system burns a CD-R disc, the system writes the files to be recorded to an intermediary area - this area must have enough free space to hold an entire CD's content).
  • Select the CD recording speed (Fastest, 4X, 2X, and 1X).
  • Select whether to eject the media after recording.
  • Click OK.
Perform the following steps to record to a CD-R:
  • Insert a blank CD-R disc into your CD burner.
  • Copy or drag the files or folders to be recorded to the CD-R drive, or right-click on the files or folders and select Send To, Writable CD.
  • After you have copied all the files, select the CD-R drive from "My Computer" and you'll see the waiting files as "Files to add to the CD."
  • Right-click the CD-R drive, and select Write to CD.
  • Enter a name for the CD-R disc, and click Next.
  • The files will be written to the CD-R disc.
  • After the system writes all the files, it will eject the CD-R disc (if you chose that option above).
  • Click Finish.
Jun 06, 2008 | Acer Computers & Internet
Cannot copy files to DVD disks
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Laptop CD/DVD Drive
In order to copy files to a CD like a hard drive you need a program that can treat the CD like a hard drive. Sometimes called *drag and drop or drag to disk*, is this what you?re using and if so what program are you using?
Mar 31, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
