Question about Dryers
I THINK MY HEATING ELEMENT WENT OUT ON MY DRYER. HOW CAN I TELL FOR SURE AND HOW DO I REPAIR IT. IT WILL NOT DRY ANYMORE AND SEEMS TO OVERHEAT. I HAVE CHECKED THE LINT TRAP AND HAVE FOUND NO MAJOR BLOCKAGE.
    Problem Solver:
  • 12 Answers
First, make sure dryer is unplugged before removing cover. locate you heating element and with a multi meter or volt meter put dial on ohms setting or the setting that beeps when leads are touching together. your heating element looks like a coil of wire. remove the wires connected to each end of heating element. take the leads from volt meter and place the lead on one end of the coil and the other end on the opposite. if you do not hear a continuous beeping sound or no reading on your meter it is bad. if you do it's not. check internal clogg or the thermal fuse located near exhaust duct. the heating element has to be replaced. rwpfn@aol.com
Posted on Sep 03, 2010
Replaced heating element. Dried one load of clothes and element went out again. What could be the problem?
The likelihood of a second element failure is very remote, unless the element suffered some damage, like bending or chipping.
It seems more likely that you have a thermal limiter that is opening. There can be two or more, and they are in series with the power to the element.
Unplug the dryer and test the thermal limiters.
Another area to look at is the control switch. Long story short, there is a ton of current going to the element. The contacts in the switch can carbon up and overheat.
Dec 10, 2014 | Maytag Centennial MEDC400VW 7.0 Cu. Ft....
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
CLOTHES DRYER HEATING ELEMENT
The heating element is SUPPOSED to cycle on and off. That is normal. There is an Internal Bias Thermostat and a Hi-Limit Thermostat that help regulate the internal operating temperature of the dryer. However, if you are experiencing longer dry times, or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases and the heating element will appear to glow brighter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Mar 15, 2010 | Kenmore 64742 Electric Dryer
Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
Jan 16, 2010 | Frigidaire AEQ6000ES Electric Dryer
WHIRLPOOL LER5644AWO DRYER
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know and I can tell you how to troubleshoot your heating circuits and/or assist you with identifying parts. Since your dryer IS heating (but poorly), I don't think you need parts. Just a good cleaning. I hope this helps you.
Dec 30, 2009 | Dryers
Just pumping out cold air
There is no fuse...
Sounds like it could be your thermostats and or your heating element that needs replacement
Sep 24, 2009 | Hoover HDC6 Electric Dryer
Our dryer takes multiple cycles to get clothes dry. Eventually the clothes dry, but it takes forever.
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Jun 12, 2009 | Whirlpool Dryers
No heat
Check the following---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 29, 2009 | Whirlpool Dryers
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
