Question about Archos 504 500870 Digital Media Player
HELLO I HOPE YOU CAN HELP ME WITH PROBLEM WHEN I CONNECTED MY 504 TO MY COMPUTER THE ARCHOS SIGN STARTED FLICKERING I TRIED THE MENU BUTTON BUT NOTHING HAPPENED I GET A BLANK SCREEN EVEN SO THE GREEN LIGHT IS ON ?
  • 19,396 Answers
Hi.
If the Archos is working fine when not connected to computer, then problem is either the USB cable, or one of the USB ports.
Test using a different cable and test the archos on a different computer, if that solves the problem and Archos connects fine, replace the cable, or troubleshoot further to fix USB problem on computer.
If that does not fix the problem, then the USB port on your Archos is defective.
Also ensure that you are not using any USB hub.
Note: If Archos is always irresponsive and does not start at all, then problem is different.
Posted on Sep 02, 2010
    Brigadier General:
  • 3,917 Answers
Hi
USB hubs are available as "un-powered" and "powered". Your Jukebox will NOT work with an un-powered USB hub and may be unreliable with a powered USB hub. It is recommended for best results, that you connect your Jukebox directly to the USB port located on the back of your computer. First take a look if your battery is fully charged.You can also make a long press on the on/off button for 15 seconds; it will switch off the unit and your data will be not erased . If your device continues to stop and freeze, you have the possibility to format it from the settings menu; you can do this into settings, then select system and repair and format tools. Before doing this, you have to save all your files on your computer. Download the firmware from our Website.
Connect the device to the PC. Go in “My Computer”, you should see “Archos 504/604”.
Copy/Paste the firmware downloaded on “Archos 504/604”
Disconnect the device safely. Go to Setup > System > Update Firmware.
Please accept the solution. Do get back to us for any query.
Thanks for contacting fixya.com
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
My archos clipper mp3 player only makes a beeping sound. It does not play anything. Not only that, I can't even turn it off. I have this constant red light flashing. I have tried resetting it but it...
Hello
Try rebooting the device. Hold the power button down for 15 seconds. Then turn the 504 back on. If that does not fix the problem, then reformat the drive. Back up all your files to a PC and go to the "Settings" menu, then select "System" and "Repair" and "Format tools."
Nov 14, 2010 | Archos Clipper MP3 Player
How to contact Customer support
You can call this number and they will help you.
1-866-489-4718
Jan 04, 2009 | Archos 504 500870 Digital Media Player
Archos 504 160gb wont start up. Tried new battery still didn't work, put my battery in another archos 504 this started up no problem. Asked for help from Archos - rubbish. Please help!!!
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
Dec 02, 2008 | Archos Audio Players & Recorders
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
Jul 21, 2008 | Archos 504 500870 Digital Media Player
Only showing in black and white
Problem fixed by going to 2nd menu group (left click the menu button) display>external display and selecting s-video (this is the cable I use)
Apr 21, 2008 | Archos 504 500870 Digital Media Player
Can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Dec 13, 2007 | Archos 504 500870 Digital Media Player
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
Nov 16, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
54 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
