Sounds like a problem with your micro SD memory card. Is it bigger than 2GB ? And have you tested the memory card elsewhere ?
Well sort of, when I use the Micro SD via the adapter in my computer it asks to format; I'm scared of losing the Data on the Micro SD, is that the only option?
Whatever you do, DO NOT FORMAT or else you will lose your data. What you should do straight away is to copy the data on to your PC/Laptop so that you have a record. Do you have another SD memory card to test with ?
