Question about Dishwashers
My Frigidaire dishwasher model #FDP1050REB, brand new, won't work
Everything is connected according to manufacturers instructions and the wash cycle button will flash but it will not "come on" or run. HELP!!! Please. This is a gift for my wife for mothers day.....
    Genius:
  • 1,073 Answers
Check for a lock out option if it has none then there is a problem with the control panel it will tell you in the owners manual also if it has the lock out button and how to disable it
good luck for mom
Posted on May 11, 2008
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
Brand new LG LDF6920 makes a whistling/high pitch squealing noise even during 1st test run, no dishes no contaminants added. It is during the wash motor cycle once the wash pump gets up to speed *screech*....
I had a brand new Dishwasher do that, it wasn't an LG it was a Frigidaire i think, turned out to be some bits of plastic from the manufacturing process that were in the pump. I had another one that made thumping noises and turned out to be a little piece of the tape, you know all that blue or green tape they hold everything in place with when its new. Did you run it through a few cycles and see if the noise quit? Believe it or not when i called about the one that was squealing their customer service said to run a couple cycles to remove anything that might be in the pump from manufacturing, sure enough midway through the second wash cycle it just went quiet and never made another noise again after two years.
Jan 11, 2018 | LG Dishwashers
Model FDB1100.......brand new Dishwasher stays in wash cycle for hour and a half........any suggestions??
Hello, Thank You for using FixYa. I will be helping you today.This is normal for new dishwashers to run this long. Heavy duty cycles with options selected can run well over two hours. Your machine is ok..This is our number one service call for new dishwashers. One hour to an hour and a half if average.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
My dishwasher is installed, but it won't go past the "washing" cycle. I have very hot water and am not using the "sanitize" option. Any ideas what could be causing this?
Your Question:
"My dishwasher is installed, but it won\'t go past the "washing" cycle. I have very hot water and am not using the "sanitize" option. Any ideas what could be causing this? "
Hi, I have ideas about your dishwasher. It apparently has a failed timer.
If this is a new dishwasher installation of a new machine. Then it is defective and is covered under the manufacturer's warranty.
The hot water issue is fine. A dishwasher's internal water temperature should be at least 140 degrees, so the machine will heat up water to accomplish this.
I would cancel the cycle the machine is in test it in various cycles.
I would try it in sanitize as well. If it completes the full cycle. Then use it.
However, if it hangs up again. I will need a new timer mechanism.
Hope this helps. If you have any questions at all, reply to me through this website.
Best Regards,
Mark
Jan 22, 2011 | Frigidaire Professional Series 24 in....
Brand new dishwasher does nothing but wash & rinse
Time for warranty replacement or repairs! Good luck!
May 14, 2010 | Frigidaire PLD4375RFC Dishwasher
"Runaway Dishwasher"
Ask for warranty repair or replacement.
Jan 30, 2010 | Frigidaire PLD4375RFC Dishwasher
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Non-functional
CHECK FOR A FAULTY WATER INLET SOLENOID
Oct 22, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
