Question about Dryers
Runs no heat kenmore model number 11074912200
  • 114 Answers
Most likely a defective heater or open thermal fuse. If thermal fuse is open and replaced, make sure exhaust vent to outside is clear of any obstruction. If you don't, you could have a recurring problem.
Posted on May 10, 2008
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
Kenmore dryer heats at first but then stays cool.
Check that the air entry and exit passages to and from the burner are clear of lint or a stray sock.
Aug 23, 2009 | LG DLG5932W Gas Dryer
Kenmore dryer model #86870100 runs but no heat
this kit mounts on the heater element chamber. The small one will be open. The big one failed also because it is rated to shut down @250°F. The little guy is rated at 300°F. NOTE: when this limit fails it is a sure sign of a blockage of lint somewhere.8e8a912.jpg
Dec 15, 2008 | Kenmore 63942 Dryer
KENMORE 41781142000 DRYER NO HEAT BUT RUNS...
temperature selecctor switch or timer is bad
Nov 25, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryer runs no heat
the kenmore is manufactured by Whirlpool. there are thermal overloads in the blower housing and one in back where the elements are. if these overloads open, 1) motor won't run 2) element won't turn on. check for an obvious open element.
Sep 13, 2007 | Kenmore 63942 Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
