Indesit WM12X Rubber door seal removal please
barkencoa
  • 3463 Answers
SOURCE: manual for intergrated indesit wm12x washing
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
barkencoa
  • 3463 Answers
SOURCE: I need to replace a washing machine door seal
It would be adviseable to rempve the top, and also tilt the washer to the rear, as it makes it easier to change the seal, and gives you more room to get your hands in.
Please rate my comments.
Thanks.
Posted on Oct 30, 2009
Testimonial: "Prompt and accurate feedback. Many thanks."
SOURCE: replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Posted on Jan 03, 2010
I have a indesit 90cm duel fuel cooker can some one tell me how to dimantle the oven door so i can clean in between the two pieces of glass
first you need to remove the door from the oven, Open the door fully and on the hinges you will see a little flap bit on each hinge, flip them over so they lock the hinges open.
Left the door up slightly and you will be able to remove the door.
Place the door on a soft surface handle side down and remove the screws around the edges, You will see how it is held together and be able to finish taking it apart.
When putting it back together make sure the insulating material and the rubber seals are located correctly.
Mar 06, 2012 | Indesit Kitchen Ranges
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
I need to replace a washing machine door seal (indesit wm12x). Do i need to remove the top or can i do it from the front ? Any other tips on the procedure would be great. Thanks
Thanks.
Oct 30, 2009 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
TEAR IN SEAL ON AN INDESIT INTERGRATED WASHING MACHINE...MODEL NUMBER WM12X. IS THIS EASY TO FIX,THERE IS ALSO MOULD ON IT...MAKING IT SMELL, ARE THE PROBLEMS LINKED ?
the fitting of the seal depends on the age and wether the tank assembly has been changed as there were two different fixings one was a spring fitting and the older version was a clamp which requires a tool to fit.
the mold is rotting washing powder which can be reduced by putting a cleaner through once a month.
Aug 05, 2009 | Indesit W 123 Front Load Washer
I have purchased a new door rubber seal(indesit W103) as the old one was split. i have removed the old one but cant work out how to put the new one on. It looks like theres a technique to it. please help
Fantastic walk-through, thank you! These instructions also work for the Indesit WIA111
Getting the seal back on is tricky - if you feel you have to really force in back on (like a tyre on a bike) then you are probably doing it wrong.
I found once I had the knack it was best to stasrt again in the least accessible place
Jul 30, 2008 | Indesit Washing Machines
I have a indesit wm12x,and the door will not open. i think the handle spring has gone because the handle is loose and the door is stuck. could someone please tell me how to open the door. thank you
you can open it from the inside, take the lid off ensuring its disconnected from the mains, u will see the back of the door catch unit (with a torch). i managed to open mine with a screwdriver :)
Mar 29, 2008 | Washing Machines
Rubber door seal problems
Try gorilla glue ,it needs to be wet with water to be its strongest.Please rate this .Thanx!
Apr 25, 2007 | Indesit 24 in. D63 Free-standing...
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
