Question about Panasonic PT-47WX49 47" Rear Projection Television
Conversion Problems it started with the 3 blinks, and after reading about it, I replaced the conversion IC's. The unit powerd on, picture showed on screen with shadows ( green blue and red), and now it's blinking 3 times again. The 140V point, measures about 75V. Also, can't find the IC's that are printed on board under # of blinks / problem Please help.
  • 34 Answers
Hello
did you also replaced 1 ohm resistor on the board. if it looks like its been hot or something.
Thankyou
Posted on May 10, 2008
HOW VOLUME CONVERSIONS ARE DONE?
On the calculator there are conversions of capacity (gallons (US or UK) to liters, liters to gallons (Us), gallons(UK) but there are no conversions from ft^3 to m^3. However you have the basic conversions from in to cm, cm to in, yd to m and m to yd. That is all you need.
To use the calculator to perform a conversion from ft to meters, you enter the number of feet, you press [SHIFT][8] (Conv).
The calculator prompts you to enter a number between 01 and 40. Each number corresponds to a particular conversion. In this case you enter 03
For example convert 3 ft to meters.
Enter 3
Press [SHIFT][8] (Conv)
Prompt: CONVERSION Number 01--40
You enter 03 (ft to m) and press [=]
Calculator displays 3 ft >m, and on the second line 0.9144
Thus 3 ft=0.9144 m
Once you know how to convert one unit of length to another, you get the volume by raising conversion to the 3rd power.
For this to work, you must convert all dimensions to the same unit.
Oct 28, 2013 | Casio FX-115ES Scientific Calculator
Everything in picture has a red outline tried
Howdy,
It sounds like you are having a problem in the conversion circuit. The outputs IC’s for that circuit have failed and are need of replacement. The average cost is at least $450 on one trip. Call an Authorized Service Dealer for repair and estimate.
The conversion circuit is the circuit that aligns the picture.
Good Luck, Big Irish.
Nov 21, 2009 | Toshiba 57H81 57" Rear Projection...
The buttom of the TV is not clear, lines of diffrent colors showing with the screen
Howdy,
Nov 21, 2009 | Televison & Video
Conversion problems
What model number. Likely your conversion amplifiers and a resistor or two have gone out. Most Toshiba's use STK392-110 which can be replaced with STK392-120. You always replace both even if only one was bad.
Jul 04, 2009 | Toshiba Televison & Video
Problems with 52in HDTV
NO this is a condition known as convergence problems. first question in menu then go to setup and see if the option of convergence is in the menu. is the picture bowed in from the top and bottom. do you have the option of autoconvergence. does it work and how far does it get. there is a common problem with these sets. and may be a simple fix if you can solder a part. so let me know and we will continue to troubleshoot.
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
VS-50705 Picture shrinks to the top of the screen. Now I have it in a room that is 60 degrees, no problems!
now a days, TV don't have replaceable parts any more. the next best thing is to replace the board. it could be the HV, horizontal or the valiance.
Oct 21, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Toshiba 42HP95 color issue
this is the cause of the conversion IC , replacing the conversion IC will fix this
Oct 18, 2008 | Toshiba TP55H60 55" Rear Projection...
Whats wrong with my color conversion?
You have convergence IC's that have to be replaced. There are 2 of them I suggest U replace both as in about 3 months the other will have to be replaced and you will be facing a double service call and labour bill if both are replaced at the same time U will to only pay once.
Dec 15, 2006 | Hitachi 43FDX01B TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
