Question about Native Instruments B4 Tonewheel Set Vintage Collection
No tonewheel files found, please re intsall the B4
3 Suggested Answers
SOURCE: NI B4 II on Mac problems with tonewheel file
What I did was go was to go into the library and find the com.native-instruments.B4 II .plist and trash it. Then, start the B4 again and the window asking for the correct files should appear. If the same happens repeat the process.
Posted on May 08, 2008
The file can be found in library/preferences. deleting it solved all our problems with it.
Posted on May 09, 2009
I have it305wc intex webcam n downloaded drivers for it but as soon as i run the autorun file it says "please insert the usb cam b4 setup".please help me
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 26, 2013 | Computers & Internet
My phone is very slow. I do this problem
that usually is if you have too many files and programs intsalled just like a normal p.c slows it down . having a memory card helps .
Oct 08, 2012 | Nokia E71 Smartphone
Where is the camshaft position sensor located on a 06 jeep grand cherokee limited 4.7 l automatic ? ... also the crank position sensor
The CMP sensor engine contains a hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects notches located on a tonewheel. The tonewheel (4) is located at the front of the camshaft for the right cylinder head (2). As the tonewheel rotates, the notches (1) pass through the sync signal generator. The pattern of the notches (viewed counter-clockwise from front of engine) is: 1 notch, 2 notches, 3 notches, 3 notches, 2 notches, 1 notch, 3 notches and 1 notch. The signal from the CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
May 12, 2011 | Jeep Grand Cherokee Cars & Trucks
I already intsalled adobe flash player 10 but I chack it is not in program files.How do I knoe if it is suceedful install? I still can't watch video on line in some webs.Please help me out.Thanks.
Adobe flash player 10 is not aprogram you can access in the usual way. It is more of a 'plug-in' an accessed by other programs when required. If you go to the add/remove programs in control panel, it should be listed there.
Feb 26, 2011 | Adobe Computers & Internet
IBM ThinkPad T43 Bluetooth not working
Try Downloading, Extracting and intsalling these Bluetooth Drivers:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58617
Once downloaded and run, it will either extract and then run a setup, OR simply extract. If the file just extracts, the files will be located in C:\DRIVERS\WIN\Something...
Navigate there and run Setup.exe
Nov 08, 2009 | IBM ThinkPad T43 Notebook
May 01, 2008 | Native Instruments B4 Tonewheel Set...
Redemption backup - restore not working
I found the solution. You have to go to their website http://www.techsupportlive.com/ and intsall the update (Redemption_Upgrade_15A.exe) which was posted on April 10th, 2008.
I did that, and it fixed the issue. Oh, after you install the update, use Tools menu to repair and manage your stores as necessary.
Here is the full blurb from their website: Problem: “Invalid file” and “No items were selected” message’s displayed when I perform Restore (Full restore, File restore and Find files restore). How to avoid or over come this problem?
Solution: This kind of problem occurs when the drive letter of the HD partition changes it can be resolved either by changing the existing drive letter of HD part to the original letter or by upgrading to the latest version as available in the techsupportlive.com and perform the Repair Catalog operation.
Mar 05, 2008 | Acomdata HybridDrive E5 Hard Drive
Motorola V3x cellular phone
have you tried this? make sure that if the other persons bluetooth is not permently turn on that they select 'find me' in the setup selection. settings - connectivity - bluetooth link - setup - find me. good luck
Feb 12, 2007 | Motorola Mobility RAZR V3
Mp3 player 512mb wont open all the way
try re-intsalling the progam disk that came with it, than format the whole mp3 player & it should work
Jan 02, 2007 | SanDisk SDMX1 MP3 Player
Computers & Internet Logo
535 people viewed this question
Top Native Instruments Computers & Internet Experts
Dan Shibata
Dan Shibata
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Native Instruments Computer and Internet Expert? Answer questions, earn points and help others
