Question about iLO 3200 32 in. LCD Television
3267HLU -- 32" Toshiba Regza LCD that will turn on and sound works just like normal, but the picture is almost non-existent. I say almost, because if you hold the screen in the optimum light and hit the menu/input buttons you can faintly see the graphics in dark grey. Not even remotely as contrasting as black and white TV. Please help, as this TV is new to me and I have been looking forward to using this unit for quite sometime now. Ideally, if someone were to stop by the shop in Lakeville, or meet as well
SOURCE: Remote is not working
I have the same thing. NOTE THE TROUBLE IS NOT IN THE REMOTE IN THIS CASE. It is in the control ciruits OR the power supply ciruits which operate the control circuits. [I think}. My set is "stuck" on chan. 10, I get a great picture, the volume is "stuck" where it was when the trouble occurred; I was changing the channel with the +/- controls on the remote when the trouble occured- I am not sure if I heard a sound from the set when it stopped responding or not. Now, there is no response in the set to the buttons on the set or the buttons in the remote- OTHER THAN ON/OFF. -and re. the on/off- when I shut the set off with the remote- th picture goes dark as it should pretty immediately- but there is about a 15sec delay before the sound shuts off [and the pilot light on the set goes red at that point also] I have opened the back of the set [I bought the set from a crook on ebay, it had been opened, past warranty anyway] and I MUST ADMIT I AM VERY IMPRESSED WITH THE QUALITY/CRAFTSMANSHIP I FOUND THERE. THE THING IS RATHER BEAUTIFULY/STURDILY MADE!! dOES ANYONE HAVE A SCHEMATIC FOR THIS SET OR KNOW OF ONE THAT HAS BEEN FIXTD?? DAVIDO ideals@cox.net
Posted on Jun 20, 2007
  • 3 Answers
SOURCE: lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Posted on Jan 08, 2008
SOURCE: ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Posted on Oct 18, 2008
  • 58 Answers
SOURCE: sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Posted on Dec 08, 2008
SOURCE: TV is "frozen" on one channel and one volume. No functions work.
cannot change stations, volume or input methods
Posted on Jan 08, 2009
32"toshiba regza no picture/ sound ok
lock for picture on the lcd but thi picture have to be very dark open it check for blown capacitators or blown fuses :D
Sep 22, 2010 | Toshiba REGZA 32RV530 31.6 in. LCD HDTV
Where is the service center of toshiba regza t.v here in manila
regza 32pb1e tv looks like there's a crack in the lcd.how to repair this and how much?
Apr 07, 2010 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
No picture, no sound. tv less than oone year old. toshiba 32" HD TV. Failed without warning
GO IN TOUCH WITH TOSHIBA AS THE SET WILL BE UNDER WARREN TIE ........SO FREE REPAIR AND SERVICE
Nov 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
I have a 32 " 1080 PI LCD Regza. Have audio but no picture. Menu items come up on screen, but no input from Sat. Box, Xbox etc..
check your power supply. and check your
invert board back lamp driver if you have a
miltmenter check your vote at the invert board.
if you do have the rigth volt yiu have a bad invert board.
Aug 10, 2009 | Toshiba REGZA 47HL167 TV
Nopicture
check all connections, use new video cables if necessary. Also you may want to remove rear cover of televison and check for loose wires and loose solder joints.
If everything checks out ok, then the problem may be the color tubes, or a main system board or video board problem.
Mar 31, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Jul 01, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No picture, just sound
No new video card required. I just reset the television by holding the on/off button for five seconds (yellow light on front panel blinks repeatedly). I then cycled power using the remote control and my picture came back. Worked for me. Hope it works for you.
May 19, 2008 | Toshiba 32A3000 32A3000 32 16:9 Multi...
Toshiba Regza 32"
I would return it, sounds like the bulb died.
Feb 22, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
iLO 3200 32 in. LCD Television Logo
43 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
