Lexmark c524 113.02 printhead service error - Office Equipment & Supplies
  • 628 Answers
SOURCE: I am getting a message
The message indicates that the laser scanning head is defective. Lexmark calls it a printhead. Unless you want to spend a lot of money, it may not be worth fixing. A new part runs over a hundred dollars.
Posted on Dec 01, 2008
  • 300 Answers
SOURCE: Lexmark Colour C752 108 service printhead error
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
“RIP Board” on page 4-11
If this does not fix the problem replace:
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the “Printhead Adjustments” on page 4-1.
Posted on Jun 03, 2008
  • 412 Answers
SOURCE: 931.01 Printhead Service Error
there is a Printhead error - No first sync
Posted on Mar 09, 2009
wyomork
  • 3 Answers
SOURCE: Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Posted on Apr 27, 2009
  • 320 Answers
SOURCE: Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Posted on Nov 28, 2009
Lexmark e450dn 935.15 service printhead error
935.10 error usually means dirty lens only. clean the lens with lint free cloth. do not use compressed air as it will force toner into the printhead assembly.
Apr 22, 2014 | Lexmark E450dn Laser Printer
Lexmark 650n printhead Service Error 935.26
110% faulty Printhead. Part required is PN: 40x4463
Easy repair, both side panels and top cover removal then just unbolt the Printhead and replace.
Dec 02, 2012 | Lexmark Office Equipment & Supplies
I have a lexmark x203n with error codes 931.01 and say No firt Hsync.
Thank you for contacting FixYa with your printer error.
What the error means
A Printhead Error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
NOTE: On the E250d(n) models, all service errors are signified by the flashing of all of the lights. To determine if this is a printhead error, quickly double-press the pattlnk_312007_2142-continuebuttonicon_e120_en_us.gif button to see the secondary code. If the !, pattlnk_3132007_1545-paperjamicon_e340_e342_en_us.gif, and pattlnk_3132007_1542-continuebuttonicon_e120_en_us.gif lights are the only ones blinking, a printhead or a motor failure is indicated. For more information on deciphering the error lights, click here (PDF file, 255KB).
Follow steps in this link to clear the error.http://support.lexmark.com/index?page=content&locale=EN&productCode=LEXMARK_E250D&segment=SUPPORT&userloc
Jun 11, 2011 | Office Equipment & Supplies
Lexmark Prospect Pro 205 printhead error
Sounds like you need new printhead. Take a look on amazon for replacement, here: Genuine Lexmark 100xl 100 Print Head 14N0700 14N1339 Printhead for Lexmark.... I hope this was helpful, Cheers
Jan 07, 2011 | Lexmark Office Equipment & Supplies
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
It will not print and is reading 935.15 Service Printhead Error what do i need to do to fix this?
Here's an article in the Lexmark website on A Printhead Error Is Appearing on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/9GQzbO. If all else fails, it may require service. I would also suggest you replace the power supply.
Jun 20, 2010 | Lexmark E450dn Laser Printer
JUST INSTALL MY NEW PRINTER, LEXMARK C540 SERIES, I KEEP GETTING A ERROR MESSAGE THAT READS 100.08 SERVICE PRINTHEAD ERROR. WHAT DOES THIS MEAN PLEASE? I HAVE INSTALLED AND UNINSTALLED TO REINSTALL. THE...
Most of the time the problem can be resolved by reseating the printhead cable which can be accessed by opening the back cover of the printer. If that won't resolve the problem, I recommend to have it serviced. It's a possible defective printhead.
Apr 29, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark C510 - 930 Printhead Error
93x Printhead Error
Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
ALL printhead errors:
If this is the first time the error has occurred, try turning the printer off and on.
Let it sit turned off for at least 20 seconds before powering it back on.
If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Source: Lexmark KnowledgeBase
Jul 28, 2008 | Lexmark C510 Laser Printer
631 people viewed this question
k24674
jasbo
jasbo
