Question about BenQ FP531 15" LCD Monitor
FP531 Monitor flashes 'Benq'
I have had this monitor for a few years but have been having problems over the last month. It intermittently startes flashing. In order to rectify the problem I have to play around with the power cable. Then all is well maybe for only a minute or sometimes fine for 2 hours.
  • 1 more comment
  • mylili May 30, 2008
    When powering on the word BENQ keeps flashing on the screen. At first i started hitting it and then the proper image would come on. When it started doing it while I was working, I brought it back to the store. It is 3 years old but my extended warrantee is good til september. Naturally it worked well there. I was told to update the driver. I did it 2 days ago. It worked beautifully yesterday but started again today! Any idea?
  • Anonymous Aug 16, 2008
    same prob
  • curmimatthew Oct 02, 2008
    Do you think that the problem is a dry join? I have the same problem. I wish to fix it myself what should i do? I didnt find any dry joints.
  • 558 Answers
Sounds like an internal issue with the power board service tech should look at it
Posted on May 10, 2008
Black monitor screen fp51g q5t4
> Check Windows proper running or not.
> Have a HDD problem, so check it.
> Check keyboard num Lock coming light or not. If not coming light then RAM problem.
> If all thing is ok then change monitor scree.
Thanks..
Sep 05, 2013 | BenQ FP531 15" LCD Monitor
BenQ Change language after i shutdown the computer ?
Using it since 2011 and the same problem started in few months. send back to claim warranty. they change internal board. was ok for few week until the problem back. never send back for warrranty as it took nearly two months to them to replace the piece. never going to get another benq product after this!
Sep 16, 2012 | BenQ V2420H 24" W Extra Slim LED Backlight...
On starting moniter shows out of range
One of three things wrong:
1. Cable on Monitor or Computer not plugged in. (Rarely a bad cable)
2. Wrong or corrupt driver. Go here BenQ Support Win 98 2000 and XP
3 Defective or unplugged video card.
J
Alright, now it is time for you to rate this answer and leave me a comment if this worked for you. J
Thanks for using FixYa - a4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated forthe FREE answering of your question.
May 08, 2011 | BenQ FP531 15" LCD Monitor
My monitor was working for a while and now the screen is black but the monitor is on and the screen flashes the desktop but only for about 1 sec then goes black again how do i fix this problem
Check the caps for leaking/bulging tops first.
It can be power supply, backlight inverter circuits problems.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 10, 2010 | BenQ FP531 15" LCD Monitor
The problem is a mssg in the midle of the screen frecuency out of interval
Have recently moved and after connection, a message in the middle of screen OUT OF RANGE
Oct 14, 2009 | BenQ FP531 15" LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Blinking BENQ FP531 continuosly...
you probably have a loose wire in the unit, you might have a bad vga cable, except for the vga cable, you will probably need to send it in for service.
Apr 18, 2009 | BenQ FP531S (Silver) 15" LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
FP531 Computer monitor operational manual
Monitor Help The size is an important factor of the computer's running resolution. When picking the resolution.
Cant find your maual on sites, contact your computer manufactor for the maual.
Dec 19, 2007 | BenQ LCD Power Adapter for FP951 Monitor
Monitor flash
Does display switch on and off with front led remaining on?
Samir
Nov 17, 2007 | BenQ FP531 15" LCD Monitor
BenQ FP531 15" LCD Monitor Logo
317 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
