Question about JVC MX-GT88 CD Shelf System
Problem with My JVC MXGT88 COMPACT COMPONENT SYSTEM
The disc tray just would not open.
  • 273 Answers
SOURCE: JVC UX S77 my 5 disc cd says
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
Posted on May 16, 2009
SOURCE: Need to set clock on jvc compact component stereo
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Posted on Mar 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: My jvc compact component system
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
AJIN G
  • 6694 Answers
SOURCE: JVC /MX-D761T/ compact component system> The
hi,
Is there is power in your system. is there is any power indication.if not then you have to check the Powre transformer, its fuse, and the small standby transformer near the power transformer. If the stanby transformer is faulty then there will no power indication in your system.
If there is power and the cd is not reading then, You have to check the laser pickup unit inside your system. First of all purchase a laser cleaning cd and insert the same in to your system. If will clean the laser pickup unit to some extent. if then also it is not reading any cd then the laser pickup is faulty. As it has a changer mechanisum it will be difficult to you to replace the lase pickup unit.Because you have to remove so many parts from the mechanisum to reach to the laser pickup unit. If so try to consult some one experienced in it.
ok
Posted on Jul 30, 2011
flygirl6744
SOURCE: JVC HX-D7 Compact Component System turning itself off
i have tired all of them so now what can i do
Posted on Aug 26, 2012
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
CD player doesn't work . the door to the 6 disc changer won't even open
This happens when the disc loading mechanism becomes faulty. when this happens the mechanism fails to load the disc to the right place thereby not allowing the optical lens which is supposed to read the disc to be able to read from the disc. All you have to do is get the loading motor and mechanism serviced and checked. This should get the door to the loader to start opening and in turn solve the working issue.
Hope this solution has been helpful?
Mar 05, 2011 | JVC MXKC4 360-Watt Compact Component Audio...
Hi There, I have a jvc compact component system...
I have the same probleme; What I can do?
Thank you for help.
May 20, 2010 | Audio Players & Recorders
Need to set clock on jvc compact component stereo amp
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
How to unlock the disc tray on my JVC compact component system MX-KB30
If your CD player dose not respond to normal commands, there is a problem with mechanism. Have serviced
May 10, 2008 | Audio Players & Recorders
JVC Compact Component System MX-D402T Problem
Hi ryv
The unit may need to be hard reset. Disconnect the unit at the wall and leave unplugged overnight and then try again in the morning, If this does not solve the condition, then it will need some repair work done to it by a JVC Auth service guy.
regards
Graeme
Apr 26, 2008 | Audio Players & Recorders
JVC MX-GT88 CD Shelf System Logo
94 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
