Question about Linksys Computers & Internet
Hi,i have a problem setting a password for my wireless internet router ,can u tell me how to do it ,thanks
  • Linksys Master
  • 32,281 Answers
Connect a LAN cable from your computer to the LAN port on the wireless router.
Open a browser and enter the router's configuration URL.
The Linksys configuration URL is
http://192.168.1.1
and the default login = admin
the default password = admin
To secure your wireless router from unauthorized access and to configure the wireless card in your computer to connect to the wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Sep 02, 2010
mlake33
  • 427 Answers
SOURCE: Linksys Wireless-G 2.4GHz Broadband Router
If you press and hold the button o the back of the router that says reset for 30 seconds, the router will restore factory defaults. Then, your routers password will be reset to "admin"
Posted on Apr 12, 2008
SOURCE: Password settings
Greetings!
I am presuming that the address you are using, 192.168.1.1 is the address from the user manual. This may not be the address that is actually assigned to your router however.
The Linksys Router can be configured in one of two ways, either with a static IP Address or by DHCP, a service that automatically assigns an IP from a DHCP Server on your network.
An easy way to test this is to go to a PC on your network that you know is functional and uses the Linksys Router as its network access point and open a command prompt from the start menu (start/accessories/command prompt).
At the command prompt type in tracert www.fixya.com and hit enter. The first address that you see in the traceroute is the IP address of the Linksys Router.
Write this down IP down and then plug it into your web browser. A login prompt window will appear on the screen. Do NOT enter a login name in this prompt - the default for admin is nothing. Simply input the admin password and the web browser will open to the admin page on the router.
As you are configuring a new network security password and protocol be aware of a few things:
1. WEP and WPA are two types of security used on these routers. Of the two, WPA is the more secure, however there may be devices and or clients on your network that do not support WPA. Prior to selecting WPA verify that there are no devices that cannot use that standard.
2. If you are adding a new security profils (password) and retaining the existing login passwords (keys) then your network will continue to function as it has, however if you delete the existing keys (passwords) then you will need to go to each computer/device on the network and update each with the new login information.
Once you have decided upon the security protocol you intend to use (WEP or WPA) you must then do the following:
1. On the router admin page click WIRELESS and then WIRELESS SECURITY.
2. For WEP you will set the Encryption Size and then enter a passphrase. The router will generate a key in hex and you will need to write down this key and provide it to the users on your network. If you change the passphrase later the key will also change and you will need to repeat the above.
3. For WPA, you set the encryption type and then enter a passphrase. Provide this passphrase to the users as that is how they will authenticate using WPA.
Posted on Nov 15, 2007
jessee007
  • 310 Answers
SOURCE: Cannot Set Password on DI524 Wireless Router
are you trying do set this pluged into the router or wireless? allways set your router setings directly pluged into the router
Posted on Dec 31, 2007
peglegcards
  • 89 Answers
SOURCE: setting passwords on dell truemobile wireless router
Hello, The default address for the dell truemobile 1184 is 192.168.2.1 If you have changed it and forgot, unplug the router (elec) for 5 seconds. This will reset it to default. The default SSID is "wireless". If a user ID and/or password is asked for enter "admin". Here you can change settings, enable broadcast, change SSID, enable WEP or WPA. Hope this helps.
Posted on Mar 17, 2008
AmrSabri
  • 59 Answers
SOURCE: How to set up a password for 3com router?
Hello celinegroot,
I made a video for you explaining in simply method
There is the Video on YouTube
Thank you for using FixYa.
Posted on Apr 21, 2009
Hello, I use a D-Link 2310 router and have forgotten my password. Friends tell me that htere is a way of getting it back without setting everything up again, can you please help. Thanks
In order to find the wireless security page of your Dlink wireless router DIR-2310 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Dec 31, 2010 | Computers & Internet
Need password for my wireless router
the username may be admin and password may be admin or password
Dec 08, 2010 | Computers & Internet
My Netgear WNDR3300 just quit putting out a wireless signal. I just bought a new Compaq notebook and the wireless internet was working for like three days and now nothing. And it is running windows 7 and...
It seems that router wireless setting need to reconfigure,please follow steps to resolved issue
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
now try to reconnect wireless
Thanks for using Fixya
May 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Need password for 2wire271 for ebook reader. Thanks
Contact the ISP (Internet Service Provider) who provided the 2WIRE router to you. They will tell you the "default" password, and will tell you how to "configure" your wireless network to be "secure".
At that time, you will set a password.
Apr 23, 2010 | 2wire HomePortal® 1800HW Router...
Forgot my wireless internet password
You have to login to router ,for wireless password
following is the way to login to router
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
Hope it can resolved your issue
please rate the service if issue resolved
Apr 04, 2010 | NetGear WGR614 Wireless Router
Limited or no connectivity
It is dhcp server issue.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to advanced and enable dhcp .
Then save settings and then restart .
Also you can set ip addrese manualy but make sure it is in range with router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Need to set a password for my blitzz wireless router
If you type www.routerlogin.com into the internet url bar, it'll ask you for the password for your router.. Just leave it blank and you can access the router settings menu and change your password in there. Write it down! Also, if you want you can enable WEP or WPA encryption protection for your wifi connection in there too, and it will prompt you to confirm the password.. Write it down!
exit from the browser and it is done.
Hope this helps
Chris (ziraffa)
Jan 05, 2009 | Blitzz Technology (BWA611) Router
Router Password
That is the wireless security key or network key configured in the wireless settings of the router. Can you tell me the exact model number of the router you have?
Nov 15, 2008 | Dynex DX-E401 Router
Hi there,have just got D-Link wireless router.Have connected to internet ok but cannot set up the wireless bit (a bit thick me, not very technically minded).The wizards tells me to enter 192.168.0.1 in...
hi u just connect d-link wireless router for lan cable for computer than u explore ther internet explore u asgin ip 192.168.1.1 than comes login screen username admin password password than enter than option wireless router u asgin SSID Name Than SSID Password ok than exit than right click network places properties than wireless icon double click than u configure u asgin SSID Username SSID Password than ok
Sep 05, 2008 | Computers & Internet
Security
Hi.
Do the following steps
1. Open Internet Explorer, type on the Address Bar type http://192.168.62.1
2. You should see a box prompting you for your username and password. Enter your router username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
3. Click on Advanced Settings tab at the top, then go to Advanced Wireless tab at the side. There you can enable wireless security. Choose WPA-PSK or WPA-Personal and type your desired password then save or applythe settings. That's it.
Aug 02, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Computers & Internet Logo
113 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
