Question about Compaq Presario 700 470024-192 Notebook
It says that the ethernet controller unknown/uninstalled as well as all the drivers for it... also when i try to set up a wireless connection the option isn't even available
  • 170 Answers
Try the follow:
  1. right click on My Computer icon located on the desktop, and select "Manage"
  2. click on "Device manager"
  3. scroll down to Network Adapters
  4. right click on each of the adapters and select "Disable"
  5. then right click again and select "Enable"
now try to see if things started to work again.
if it doesn't work try searching for the driver on the HP site: http://welcome.hp.com/country/us/en/welcome.html#Support
Posted on Sep 02, 2010
Lost internet
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if these packages are not the right http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for tick in the box for windows software or all software box IE: Motherboard name Wireless or Ethernet driver you might have to try a few times to get it right
Hope this helps.
Jan 23, 2013 | Computers & Internet
How to enable my wireless
if you are referring to your internet connection
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jun 23, 2011 | MSI Computers & Internet
My smartbook computer has no ip address,and will not connect to a wireless signal
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
May 25, 2011 | Computers & Internet
How do i turn on my wireless internet
hope this helps
May 20, 2011 | Computers & Internet
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
Network Adapter/Ethernet Controller
Nothing wrong with having two network adapters installed on your computer. If you have this DWA-552 wireless adapter installed as well as an onboard NIC, the correct thing to do is have both drivers installed so you see them both in your Control Panel->Network Connections window.
If you really want the onboard nic to go away, go into device manager and disable it - not uninstall it.
Mar 08, 2009 | Computers & Internet
In having problems with connecting to the internet
go to control panel>>system>>hardware manager.
uninstall the ethernet controller.
restart the PC let eh machine find the driver.
or you can find a working PC and download the NIC driver for your PC.
Jan 30, 2009 | Gateway Computers & Internet
? Network problem
This is generally a driver glitch. Check to see if the wireless card is receiving a signal. If not, then uninstall the wireless drivers from the device manager and reboot. Th machine will find the card and reinstall the drivers. If it does see a signal, but won't connect, then try plugging in with an ethernet cable to see if it will connect. If it doesn't connect with the cable, then uninstall the network controller drivers and reboot. If the problem persists let me know and we'll try another approach.
Jul 23, 2008 | IBM ThinkPad R40 2722 Notebook
Re. aspire 1360 wireless problem
hi there,
for your first question ..yes u are uninstalling from device manager. and the second.. the wireless card not showing was taken into account..cause the ethernet controller that has the yellow mark is your wireless card..it just does not have the drivers...hence the name ethanet controller....
try this link for the card listed in your post :-
http://www.laptopvideo2go.com/forum/index.php?showtopic=7172
Apr 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Compaq Presario 700 470024-192 Notebook Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
