Question about Hitachi Cameras
I have an HDC-646E camera that tells me that battery cover is open although it isn't, also status light on rear of camera is flashing orange. Any suggestions please.
  • 20 Answers
See previous solution to this --ie microswitch lault
Posted on Dec 20, 2008
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
HITACHI HDC-646E battery cover open
This is more likely a mechanical failure - that is a micro switch actuated by opening/closing the cover.
Contact manufacturer support site for a remedy/advice.
Dec 06, 2008 | Cameras
Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
Hi X,
There's a little piece of plastic on the battery cover, that presses a switch when you slide the cover closed. Check that manually with a tooth pick and the the battery in place. Don't smash it. I have a Olympus FE -280 and it only happens when I put the cheap Chinese battery in.
If you are in the least uncertain, call Customer Service.
Best regards, Paul
Jun 12, 2008 | Cameras
Olympus mju 410- Orange lamp flashing
I had this happen and fixed it by removing the battery and leaving it out overnight and making sure it was fully charged - the next day battery inserted and it was ok. Prior to inserting battery I opened shutter cover and help down shutter release to try to drain any residual power. - Worth a try.
Oct 12, 2007 | Olympus MJU 400 Digital Camera
Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
May 09, 2007 | Kodak EasyShare Z760 Digital Camera
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
59 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
