I have a crosley tv it has perfect picture quality but it has started flickering at first it would do it awhile then stop now it wont stop paid alot for it and dont want to just throw it out
2 Suggested Answers
  • 1039 Answers
SOURCE: FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Posted on Mar 25, 2010
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Just started flickering and then black screens - still hear audio, just not picture. Turning it off for awhile lets it come back up..for awhile.
Ur high voltage is dying,it the FBT,the flyback transformer is cold solder or dying.The big black block of plastic with a red wire with a cap that hook to the CRT(tv tube).That the cause.
Sep 27, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Picture is flickering then going off
tae your tv to a w/shop tech
your tv has a dry joint or one of the active components is heating up
or a supply is varing
Mar 06, 2009 | Bush 2871NTX 28" TV
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Dec 02, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Flicker
I have the same problem when going to dark scenes from a bright scene or during channel changes. Sharp sent a tech under warranty and he installed new software to no avail. He called sharp tech support and they suggested turning on opc. The TV works fine but you must adjust sharpness and contrast to achieve an acceptable picture. I paid $868.00 for the set a Sam's club and will buy an extended warranty. I will not buy another sharp. My 40" sony works perfectly.
Oct 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
A340 screen flickers unexpectedly!
i would suggest taking batteries out overnight and letting the camera discharge the stored power. then trying it again. also make sure what mode your in because the shake warning makes certain lights flicker
Jun 14, 2007 | Fuji FinePix A340 Digital Camera
32" widescreen flat ilo tv
I have a 32" Initial which is an ILO with a name change. All I can do is turn it on and off. The volume and menu settings will not work. I have had it for about two months and now I am going to take it back to WalMart. The picture quality is great but it sucks that I can't change the volume or settings. I guess Sony will get my business now.
Feb 05, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Electro Med Services...
