Question about Brother NX-400
I live in Europe and cannot find a service person to oil my Brother NX400 machine. I am having problems with uneven stiches and computer stitches and the button hole attachment not working as shown. Is there anyway I can purchase a service, repair manuel? I have looked on line without success rfjtk5@aol.com
    Guru:
  • 382 Answers
I think I may have found the manual you are looking for, best thing about it, it is free. Simply scroll down and input the security code, and it will take you to the manual where it can be downloaded free of charge. To get the free manual, please go here If I have been helpful, please don't forget to rate me
Posted on Sep 02, 2010
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
HI, I haven't used the brother 2125 sewing machine for months. There was no stiches coming out after I started it this morning. I tried many times. The motor is fine, threads from up and the bottom are...
Totally rethread your machine and insert a new needle, you may have a bent needle. Your thread may be tangled, and your bobbin may not be inserted right. If, you don't have your manual go to brother-usa.com and download a manual for free. It should answer all of your questions
Sep 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother VX 1120.... Machine is not making consistent stitches then thread loops and stitch goes straight and half zigzag, thread breaks. Same with straight stitches...will go for about an inch then stitch...
Remove the needle plate, bobbin case and bobbin and clean any lint that has accumulated.
Oil, if the manual indicates you should do this and where it should be done. Some do not as it has to be done by a repair tech.
Re-thread the machine with the presser foot in the up position.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
If the problem continues, the machine will have to be services by a sewing machine repair person. Take samples of the stitching so they can see what it happening - it could be the timing has to be reset.
Feb 16, 2010 | Brother Sewing Machines
Singer 9410 bobbin problems
It should not affect the winding, the reason the needle is still going up and down is because the oil has gone dry on the shaft and unless you can get to the shaft where the balance wheel is then it would be wise to take the machine in for a service, loose stitching on the bottom is a tension problem, make sure the top tension is set about 4 or 5
Oct 26, 2009 | Singer Sewing Machines
Brother XL 3030 i can't seem to get it out of the zig zag stitch mode. Help
it is easy to switch the stich modes
there are two wheels on the side on the mchine
one in for manualy stiching *the big one)
and the little one changes the stitch
you have to look at the LCD screen to make sure the numbers correspond
Feb 17, 2009 | Brother XL-3030 Electronic Sewing Machine
Brother XL2230 Elastic Overlock function not working properly
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Feb 16, 2009 | Brother XL-2230 Mechanical Sewing Machine
Yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Feb 11, 2009 | Brother Sewing Machines
Tension issues!!
this sounds totaly stupid, but I just have been dealing with this exact same issue for the last 3 hours- the resoultion? I took off the stitch finger and it started working perfect! I don't understand why this fixed my problem but in a crunch works great! Perfect even stiches and blades cutting evenly as well.
Dec 10, 2008 | Brother 1034D Mechanical Sewing Machine
Brother NX-400 Logo
108 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
