Question about Epson Stylus Pro 9600 InkJet Printer
Because of power fail during printing my printer Epson stylus pro 9600 is showing "Service Req 00010020". How can I come back in business ? I have reset maintenance, check contact pins.
    Champion:
  • 331 Answers
Did you remove and reinsert the cartridges? Perhaps, clean the contacts. This is a cartridge error.
Posted on Sep 02, 2010
  • dongolrk Sep 02, 2010
    Again I check all contacts, and replace all cartridges and maintenance tank also. But still showing "Service Req 00010020".
  • TechRx Inc http://techrxgb.com
    It may be that the "ink sponge" is end of life. (This is below the print head when resting) it's a sponge that the ink drips into when the heads clean.) It reaches a "value" and causes an error. Try this Epson reset utility to "clear" the counters on the printer; see if it will run again. http://www.ssclg.com/epsone.shtml
    Keep in mind; if that sponge is too full; it will cause over-flow of ink down the road. Try blotting it with a microfiber towel, or paper towel etc.
I am Eric, I have this error message on my epson stylus pro 9600, SERVICE REQ. 00010004
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 24, 2011 | Epson Stylus Pro 9600 InkJet Printer
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Recently my epson 9600 pauses during a printing job for long periods, so that it can take several hours to complete one print.
Need more info.
Are you printing from a computer directly attached to the 9600 ?
or
Are you printing through a network.
If you are using a networked printer then your print job could be slowed a good bit by heavy network traffic.
Apr 06, 2010 | Epson Stylus Pro 9600 InkJet Printer
00010020 error
try this may be it helps you --
00010020 CSIC read / write --
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the spanner light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 00010020 will appear on your control panel LCD which is informing you that there is a problem communicating with an ink cartridge. This can be caused by a faulty ink cartridge chip or bent pins. This problem can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Mar 09, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
00010020 error
CSIC read / write error - this is the chip on the cartridges and maintenance tanks
Dec 17, 2008 | Epson Stylus Pro 9800 InkJet Printer
000100200 error
Remove the printer in printers and faxes and reinstall it with your original install cd
Nov 01, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson stylus pro 9600 driver
on site tech service for epson 9600?
Dec 31, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
451 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
